Question about Technics SL-1200MK2 Turntable
Arm Looping I just got a pair of 1200's and the needle stay in constant loop, it doesn't move on the record, stays fixated at one spot! any ideas?
  • ajghost Jan 25, 2008
    i already tried all of that i even went through all the weight levels on the arm and still it starts looping , it does it with both records and serato!
    yea i think i found the problem
    its seems that some thing on inside the tone arm is broken
    i took the tone arm made it float and turn the anti slating knob and it didn't move at all so i think i might need to get a new tone arm.
    i tried all the weight levels that didnt do much
    but what i found works is when you push the weight all the way up and put a coin on the needle not the best solution but i just need them to work tom
    if you have any other suggestions i would greatly appreciate it!
  • 515 Answers
Oh jeez. No one here has a clue about this turntable. AJ, you are correct to assume the tonearm is faulty. This tonearm has 3 pivoting screws - 2 control your vertical movement, and 1 controls the horizontal bearing. Your horizontal bearing is shot. Unfortunately, there is no easy way to fix this, and you will need to have your tonearm replaced. You can attempt to replace the tonearm yourself, however, I do not recommend it. You can purchase your TONEARM HERE or have it professionally repaired.
This is a common issue with used 1200s. People will stack stuff on top of them, and don't realize how fragile the tonearm really is. Also, if you had them shipped to you, many people will just stack 2 of these in 1 big box, and that's also how you get tonearm damage. These turntables are heavy, weighing in around 30lbs each. So shipping them individually is the best way. Never put anything on top of the tonearms.
The way the tonearm suspension works:
The 3 screws which control up/down and left/right movement of the tonearm are conical shaped screws. Meaning, they have a cone shape tip on the bottom. This cone section rests on top of 4 ball bearings, which are protected by a very thin layer of sheet metal. If any of these ball bearings or this sheet metal is damaged in any way shape or form, you will get the same problems you are experiencing. Also, this problem arises, when your tonearm screw (the top) is too tight, or misaligned. You can attempt to turn it, counter-clockwise to loosen it, but once you start messing with that screw, it's very hard to get it back to where it should be. It will release the tension, causing a stiff tonearm, but then you might end up with a loose tonearm, which is just as bad.
In any event, good luck!
DJ PRO LAB
Posted on Feb 24, 2008
  • 36 Answers
Generally speaking, needle should follow the groove, if following not present:
1. dust and grime built up in the groove that stops need to pass. you should be able to hear "click, click, click" each time needle comes to the same spot. - clean your record in details.
2. cartridge/arm bias and weight too light causing needle to skid over path. - adjust the effective bias and weight according to cartridge spec.
If problem persist, write me again.
pc-cook
Posted on Jan 25, 2008
  • 1 more comment
  • Clement Tam Jan 25, 2008
    have you checked the bias/counter balance? which pulls the arm outwards..............., if too much, the are will never travel inwards.
    answer yourself first:
    were you able to bring the arm towards the turn table spindle?
    can the arm travel freely and lightly when hand held or stopped at the looping spot?
    how much force is needed? normal or excessive?
    pc-cook
  • Clement Tam Jan 28, 2008
    I had a SL1200, but it was a long time ago. If I am not wrong, it has an "auto return" arm. In saying this, there is a "return" mechanism under the tone arm base. You have to lift the whole base out of the board to find out what stops the arm to travel inwards. To the contrary, "non automatic" arms are supported by pivots up-down and sideways which can be seen easily.
    I don't care for a vote from you unless you feel comfortable about what I said.
    good luck
    pc-cook.
2 Suggested Answers
  • 9 Answers
SOURCE: Arm Looping
ive had this problem djing in front of 700 people...Not good!! i can tell you exactly what it is, the tone arm bearings are being pinched too tight or there is a tiny piece of debris in the bearing race of your tone arm or blatentley your vinyl is scratched lol.... assuming you ve set your stylus correctly and the turntable is level on both axis???? slightly unscrew the tiny screw on top of the tone arm just enough to release the pressure on the bearings inside, but not so much that it wobbles about??? happy mixing
Posted on Jan 26, 2008
Why won't our arm on our record player advance to play record on auto control? Lifts, moves back and returns to original position.
Try adjusting the counterweight on the back. Average weight setting is 1 gram. most high end RPs have it and it's a 'turn clockwise to increase' deal.
If it's a cheapo, there may be something interfering with the arm. possible a spiderweb inside! or??
Aug 17, 2014 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Feb 03, 2011 | Technics SL-1200 Turntable
The arm won't stay down, as soon as it sets down on the record it automatically stop and moves back to the resting spot.
If you have the automatic arm on you`res and you have to move the slidder control to make it work,don`t slide the control all the way.Just til you hear a click and then move the arm you`r self.Also make sure it is set to the size record you are trying to play.
Apr 22, 2010 | Pioneer PL-990 Turntable
Mylock 634D looping left needle stitches
Make sure the thread is in the tension disks. Do this by pulling the thread backwards towards the spools. Also set the tension on zero and check for any fluff, or thread that is stuck in the disks, preventing them from closing properly. Good luck
Jan 09, 2009 | Janome MyLock 634D Mechanical Sewing...
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
Arm Looping
Jan 25, 2008 | Technics SL-1200 Turntable
Oregon Scientific MP3 120
Keeps looping from a blank Blue screen to off. Will not turn on and stay on. also will not stay turned off
Aug 26, 2006 | Oregon Scientific MP120 MP3 Player
Technics SL-1200MK2 Turntable Logo
222 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
