Question about Technics SL-1200 Turntable
Arm Looping I just got a pair of 1200's MKII and one of them is constantly looping, the needle does move on the grooves its stays fixated at one point! Any Ideas?
  • Dj illskill Apr 27, 2008
    everything seems to be adjusted properly but the stylus is ever so slightly swaying back and forth on the record causing it to skip. I have tyed everything short of taking it all apart what should I do. Dj illskill.
    Problem Solver:
  • 9 Answers
Ive had this problem djing in front of 700 people...Not good!! i can tell you exactly what it is, the tone arm bearings are being pinched too tight or there is a tiny piece of debris in the bearing race of your tone arm or blatentley your vinyl is scratched lol.... assuming you ve set your stylus correctly and the turntable is level on both axis???? slightly unscrew the tiny screw on top of the tone arm just enough to release the pressure on the bearings inside, but not so much that it wobbles about??? happy mixing
Posted on Jan 26, 2008
I am using the walking foot for a quilting project that I am working on, however, the bottom stitching is just looping and can just be pulled away from the fabric.
Be sure you are using a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE THE PRESSER FOOT and rethread the upper thread from the beginning. Make sure the thread path is correct.
Verify the bobbin is installed and turning the correct direction in the bobbin case and that the bobbin thread is threaded through the bobbin tension mechanism.
Set the upper tension to the midway point between high & low number--this may require some adjustment for your particular machine.
Pull the bobbin thread to the top of your sewing project before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Re-test your machine on a scrap quilt sandwich (make sure the walking foot is installed correctly and that the presser foot is lowered when beginning to stitch).
Consult the owner's manual for instructions for presser foot pressure. The pressure may need to be adjusted because you are dealing with a sandwich that is thicker than regular fabric.
You may also try changing the type and size sewing machine needle you are using. Using a Top Stitch or Microtext needle will help the needle to penetrate the fabric sandwich easier. A Top Stitch needle has a larger groove to protect the thread as it pierces the fabric which helps prevent looping.
Also, verify the thread is not too small for the needle's eye.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwil1tu2mb3PAhVR6mMKHUlvB_4QFggoMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Oct 02, 2016 | Sewing Machines
Looping stitches
Hello Shirley, I suggest you make sure the machine is threaded correctly. If you have a factory manual, that would be a help. It sounds as though the needle thread is not threaded through the take up arm and/or take up arm spring. The needle thread tensioner might be too loose.
May 13, 2015 | Bernina Virtuosa 160
Missing parts on singer sewing machine model 974 serial no. SH30010021
take it back to place purchased .have them correct the problem
Mar 15, 2017 | Singer Sewing Machines
Tl98e broke a needle and now won't stop looping.
needle plate may be sanded lightly for nicks and scratches. Timing is probably off, need to see an expert repair service in your area.
May 30, 2010 | Feiyue FS288
Looping underneath
I watched a 'You Tube' demo that showed ........if you loosen or tighten the very small screw at the base of the bobbin this gives you the correct tension & stops the looping under the fabric........I didn't even know this screw existed ! It is trial & era at first re the correct tension but you do get there.... the art is to do it in small mini stages.....like you hardly move it ! Thanks to 'You Tube' I can now get on and finish my drapes !
Nov 23, 2009 | Riccar R651 Mechanical Sewing Machine
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
My bobbin thread is making big loops
Bottom looping says upper tension problems (too loose). Rethread it making sure the presser foot is up so the thread is inbetween the tension discs.
Dec 11, 2008 | Bernina Bernette 75
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
Arm Looping
Generally speaking, needle should follow the groove, if following not present:
1. dust and grime built up in the groove that stops need to pass. you should be able to hear "click, click, click" each time needle comes to the same spot. - clean your record in details.
2. cartridge/arm bias and weight too light causing needle to skid over path. - adjust the effective bias and weight according to cartridge spec.
If problem persist, write me again.
pc-cook
Jan 25, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200 Turntable Logo
209 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
