Question about Kitchen Ranges
Kitchenaid kgrt607 - cleaning cycle can't lock door properly
I apologize for the second post, but the stove model didn't get included in the first - Kitchenaid kgrt607
When the cleaning cycle is started, the control tries to lock the door.The lock engages, and the door locked light goes on for about onesecond and goes off. One second later the door lock disengages. Aboutten seconds later the lock engages again, and while it is physicallylocked the locked light does not appear. Ten seconds later the lockdisengages, and this continues with it locking and unlocking, nolocking light ever on, for a few cycles before it quits with an errorcode of F5:E1.
If it is a fault with the control panel it is stillcovered under warranty and I can put in a service call. If it is thelock, it's a pretty inexpensive part. I need a way to diagnose thisfurther. I have the tools and dvm but no repair manual as to how to getto the lock, etc. Any help is very much appreciated.
David M.
  • 72 Answers
More than likely it is the latch out of alignment with the strike. If it cannot engage, then it will stop trying so it will not damage the servo. Go here to check out codes, they are at the bottom of the page, and you can order a repair manual through the same company if you can't find the info on their website, BTW, you can also buy repair parts through them, they have a complete lineup. I buy my parts through them exclusively and have for years now
Posted on Jan 28, 2008
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
KitchenAid electric range KERS807SSS02 -in the middle of cleaning cycle, NO power outage but panel went black and door remains locked even after cooling. Circuit breaker not the problem. Top elements work.
We have a Kitcheaid gas stove and have had 3 new thermostats installed. After the 3 time it finally did it's first full cleaning cycle.
So three service calls later, (first was after the warranty) and three thermosats and over $500 and the stove has done it's first full cleaning.
Lots of examples of this same problem but it seems no recall on the stoves.
Jan 08, 2010 | KitchenAid KDRP407HSS Dual Fuel (Electric...
KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Aug 29, 2009 | KitchenAid KGRT607 Gas Kitchen Range
After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Apr 14, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Cleaning cycle failure
Please call KitchenAid/Whirlpool directly and ask to speak to the 'executive management team'
I had this fault for the second time and this time I spoke to the Exec Management team who said they were unaware of this as a common fault. My stove was ‘fixed’ free of charge – the fuse was replaced, again.
Please everyone who has had or is having this problem call again – this problem needs to be fixed, replacing the fuse each time or not using the self clean function is NOT a fix.
Mar 29, 2008 | KitchenAid Architect® KEBS277S Electric...
Self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Dec 13, 2006 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
