Question about Lexmark C510 Laser Printer
913 Service Fan Error
I'm getting an error code of 913 Service Fan Error. Any suggestions?
  • Anonymous Feb 12, 2008
    914 SERVICE FAN ERROR
  • Anonymous Sep 26, 2008
    Lexmark C510 Laser Printer, on the screen it says, "914 Service" Fn error. Pls. notify me if it can remeded and fix.
Hai all i got problem regarding my MFP x854 come out error 915.00 services fan error i alreday change dual drive moot,engine card,System board ,also HVPS mfp still come out same error pls advices this problem
Posted on Aug 10, 2010
  • 21 Answers
Your printers power section does not work properly
Posted on Mar 12, 2008
If you are still having problems, the correct method of solving it is to go to magicjack Customer support. International VoIP Phone Service Customer Care Support magicJack
May 29, 2014 | Computers & Internet
We have a display error with freezer temp error "E" and fresh food temp "F".
Hello Matthew, thank you for allowing me to assist you!
Error code EF commonly refers to an evaporator fan error. Either the evaporator fan is not spinning fast enough or not at all. It is possible that there is something contacting the fan blade, which this will trigger the error code as well. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Oct 20, 2013 | Frigidaire Refrigerators
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
How i can solve the 913 service motor error lexmark sc1275 my printer?
913 Transfer Roller Error
The printer fails to completely transfer the image to the paper or does not transfer it at all.
The image transfer roll does not lift when paper is passing over it.
Suspect either the transfer roller solenoid or transfer roller motor malfunction.
The printer would have to be professionaly serviced by authorized service centre.
http://www1.lexmark.com/content/en_us/technical_support/find_service_provider.shtml
Copy and paste link above for Lexmark Service Centers.
Pre
Jan 14, 2011 | Lexmark Optra SC 1275 Laser Printer
HP 8150 error code of 57.5 comes up, I cycle power, I have checked all the cables and still comes up with error code. Does anyone have any suggestions?
Hi
Error code 57.5 in HP 8150 means that printer fan error has occurred with the power supply fan. This issue can also be due to laser/scanner fan. Make sure both the fans are working perfectly fine. If the fans are fine, then the error is due to DC controller board.
To resolve this error turn off the printer for 4-6 hours (atleast 4 hours), this will reset the error. However, even after 4 hours you still can see the error then please check and replace the fan1 (power supply fan). Also, check for any burnt components on the dc controller board.
Daniel Scott
Jun 18, 2010 | HP LaserJet 8150 Printer
Error code l4 on sharp 5316
The error means that The paper exit cooling fan is not working. Reboot machine, if the code comes back, you'll probably have to get the fan replaced. You may need a technician to this things for you, if you haven't got any idea how to service the machine.
Hope this helps.
Dec 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 Fault 9-913
Use the following procedure to troubleshoot Error Codes 009-910 through 009-913
1. Check the installation of the Print Cartridge. 2. Clear the Tech Rep Fault for errors 009-910 through 009-913 (see instructions below). 3. Try changing the indicated Print Cartridge. 4. Check for an open wire or poor contact between the Print Cartridge and the Engine Control Board. a. Yellow, J-151 to J-405 b. Magenta, J-152 to J-405 c. Cyan, J-153 to J-405 d. Black, J-154 to J-405 5. Replace the engine control board
NOTE:  Before troubleshooting for an open circuit (Step 4) or replacing the Engine Control Board (Step 5), clear the Tech Rep Fault for any of these codes first using the following steps: 1. Enter Service Diagnostics. 2. Highlight NVRAM Access and press OK. 3. Highlight Clear Tech Rep Faults and press OK. 4. Highlight link codes 009-910 through 009-913 and press OK.
Hope my info solves your problem..... Thanx for using fixya......
Oct 24, 2008 | Xerox Phaser 7750DN Laser Printer
Canon W7200 Error code E02D05
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Probable problem locations
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
IR8500 giving E000830-0000 Error code
Having trouble with my IR8500 getting Error code E000218-0000. Any Suggestions? Thanks
Nov 30, 2007 | Canon imageRUNNER 8500 Copier
Lexmark C510 Laser Printer Logo
390 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
