Question about Intel D865GVHZ Motherboard
Bios not accessable
Cannot access bios ,possible no ps2 keyboard driver? usb keyboard works only after bootup.
    Problem Solver:
  • 6 Answers
An other issue I found with Keyboard/mouse and BIOS access is that they should be plugged to USB2, NOT USB3.
Posted on Feb 12, 2015
Usb and ps2 keyboards do not post to bios at all
Posted on Jan 25, 2008
    Genius:
  • 1,067 Answers
Yes cant use reg keybord or buy one new one
SOURCE:
Keyboard doesn't work after boot
Try booting up with the ps2 keyboard.Once in Win 8.1, unplug ps2 and plug in usb keyboard. See if windows will recognize the usb keyboard and if so it should install software and drivers
Nov 19, 2013 | Gigabyte Computers & Internet
G31-M7 TE keyboard problems
you have to run the DRIVERS CD FIRST.
Apr 11, 2013 | Biostar G31-M7 TE Motherboard
GA-Z68AP-D3 wont recognise keyboard
This sounds very much like a faulty motherboard if it continually reboots. Try accessing the BIOS using the F8 key, however check you manual to make sure your motherboard uses the F8 key. If you can access the BIOS, it would be worth doing a complete reset to factory defaults and see if this fixes the problem. If you cannot access the BIOS, then you will be looking at a new motherboard.
Nov 26, 2017 | Gigabyte Computers & Internet
I want to change keyboards
Hi Richard,
most enhanced keyboards need a specific driver to run.
Go to the manufacturers website to download the driver. or search on Google.
You might also have to enter BIOS (accessed when the computer is booting..look for a message that tells you how to get into BIOS, or look in your user manual). Often it can be accessed by pressing the DELETE or F1 key just after you power up. The option in BIOS you may have to change is something like "enable Legacy support for USB".
Have you tried looking in the Dell support website? As you just recently(?) bought this, you can ring up Dell support centre and ask them to help.
Cheers,
Steve
Jul 11, 2010 | Dell Inspiron 519 Desktop PC Bundle
Keyboard error or no keyboard present, the
Have you tried to disable the PS2 keyboard and plugged in a USB keyboard..? You may have to go into the bios and switch on USB legacy support..
Nov 12, 2009 | ASUS P4B266 Motherboard
USB Keyboard will not access BIOS.
Hi there.
Get the PS/2 keyboard and go back into the bios, make sure all the USB controllers are set to "enabled", save the changes and exit the bios, the computer will restart and your USB keyboard should now work and you will be able to access the bios using the USB keyboard.
Good luck and thanks for using FixYa!!
Apr 29, 2009 | Computers & Internet
I can't install vista any mouse or keyboard detected
Often times this happens when using a USB keyboard / Mouse.
Or when using a USB keyboard through a PS/2 Converter.
Try using a PS/2 Keyboard if available
(Small Round connector with a small amount of pins, similar to a S-Video connector.)
Also. Access your BIOS settings and assure that you have Legacy USB keyboard support.
Depending on your computer the BIOS / Setup Menu / Options Menu/ Etc. can be accessed by pressing the following key during boot:
F1
F2
ESC
DEL
F12
Let us know your setup(KB and Mouse Port type), and if you have any other issues.
Good luck
Apr 14, 2009 | ASUS P5V800-MX Motherboard
HP USB Keyboard model KU-0133 not working in BIOS level
Winxp? an "old" computer that probably only works with an old style keyboard? just a guess.
Feb 10, 2018 | Compaq CPQ Easy Access Internet USB KB...
Bios does not find PS2 keyboard/mouse
Did you go into the BIOS and set it to recognize the USB Keyboard after you reset the BIOS? Is windows not noticing it or the BIOS. You stated that it recognized the USB keyboard and then said that it did not.
What does all of this mean? USB keyboard does not activate "del" setup.
If it does not work, it is because you reset the BIOS and did not change the settings back for the USB keyboard.
I hope that I fixed your problem.
Jun 04, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
Can't load os do you computer Dell only has usb ports
Ensure the Keyboard and mouse are connected to the USB ports nearest the PS2 port on the back of the chassis.
Boot to the BIOS F2 and ensure USB emulation is ON.
If you can't access the bios, reset the BIOS using the Jumper on the motherboard, then USB ports should then work.
May 18, 2008 | Dell OptiPlex GX280 PC Desktop
Intel D865GVHZ Motherboard Logo
183 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
