Question about Dryers
Wiring electric dryer
Attempting to free wires to replace 3-prong cord. Nuts are hard to loosen. Suggestions -- attempting using ratchet, but not loosening. Don't want to put to much pressure on one-sided anchor ....
  • 240 Answers
I would imagine that you have a Kenmore, Whirlpool, or Frigidaire model. Some sort of model that has the bolts instead of the screws. You can buy these kits for little expense if you do happen to break one off. Most of the time, the nuts on the backside will strip out the terminal block before they break. These terminal blocks are not that hard to replace either. My suggestion would be to spray some WD-40 on them, then let it sit, then respray and see if they will come loose. Also, not to say anyone would do this (but me for about a half hour one time), be sure that you are going the right way when trying to remove. Let me know what brand of dryer that you have and see if you can find a model number, and can help you with part numbers, etc. Good Luck!!!!
Posted on Jan 25, 2008
The electric cord plastic jacket melted and burned through wire on one spot. Can the cord be replaced
I am currently attempting to do that myself. You need to separate the liner from the outside part. Using a pair of pliers, loosen the round nuts (found on the bottom) holding the unit together & separate. You'll find that the unit won't come completely apart because of the wiring. There is a heating band, held together by a spring, around the inner liner. Remove the spring to release the band. This should allow you to remove the inner liner & give you access to the wiring. At this point, you'll need to clip the appliance cord by the little wire nuts. The hardest part will be getting the cord out; there is a strain relief grommet that holds the cord in place and prevents it from being cut by the sheet metal where the cord goes through. I broke this strain relief on my crockpot and am currently looking for a replacement. Once I find a cord relief, I should be able to reconnect the wiring, the heating band and assemble the unit. Be careful not to cut yourself on the sheet metal!
Nov 23, 2011 | GE 106661 4.5-Quart
Need to replace 4 prong cord with a 3 prong cord on a new 500 series dryer.
On the back of the dryer, remove the screw(s) that hold the access cover to the back panel that cover the terminal block where the cord goes through the back panel and connects to the wiring terminal power block, loosen the two screws on the cord clamp the clamp it to the back of the dryer just enough to release the cord, remove the four nuts / screws that are connecting the 4 wires from the cord to the terminal block and or the back of the dryer,with the new 3 wire cord just match the colors on the terminal block with the same color wires that are connected to the other side of the terminal block, red,black on the outer most terminals and the white or green to the middle terminal, IT IS IMPORTANT THAT YOU PLACE A JUMPER WIRE/STRAP FROM THE MIDDLE TERMINAL WHERE THE WHITE OR GREEN WIRE CONNECTS TO THE TERMINAL BLOCK OVER TO THE CASE/CABINET OF THE DRYER, THIS CAN CONNECT TO THE CASE AT ANY AVAILABLE SCREW NEAR THE TERMINAL BLOCK! In short this means that the neutral and ground of the dryer must be connected together in a 3 wire set-up.
GOOD LUCK!
Aug 21, 2010 | Kenmore 500 6952 Dryer
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 | Dryers
3 wire to 4 wir
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
What type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Jan 04, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
