Question about Apple iPod 4th Generation MP3 Player
My ipod shows a sad face
I removed my ipod from its speakers and connected it to an earphone and now it cant work anymore, it shows the apple logo and a sad face then off it goes!
  • Anonymous Feb 10, 2009
    sad face
Sad Face is almost always an indicator of a broken HD.
new ipod hard drive
http://www.ipodrefresh.com
Posted on Aug 14, 2008
    President:
  • 317 Answers
Hopefully your ipod is still under warranty, because this is indicative of a hardware problem.
You could try to force it into disk mode and do a restore, if that doesn't work then it needs to be sent in for repair.
http://docs.info.apple.com/article.html?artnum=61771
Posted on Jan 26, 2008
2 Suggested Answers
SOURCE: my ipod shows a sad face
crashed probly
Posted on Apr 13, 2008
My ipod does nothing just shows a sad face
The "sad" iPod icon usually indicated that the iPod is having trouble connecting with a computer. This is, in most cases, not a serious issue and can be resolved with a few easy procedures. In most cases the data on the iPod is intact, even if the sad icon was displayed.
Verify the iPod has a charge. If in doubt, allow it to charge for 30 to 60 minutes. Do not remove charging cable. Toggle the Hold switch to the Hold position and back. Then press both the center (Select) button and the Menu (upper part of wheel) for up to 10 seconds. Release the Select and Menu buttons when the Apple logo appears, and quickly simultaneously press the Select and Play/Pause (bottom of the wheel) button. Switch from the electrical plug to a computer connection (if necessary) when the Disk Mode screen appears. The screen should change to the normal "Do Not Disconnect" update screen. Contact Apple about finding a repair service if the iPod will not go into Disk Mode.
Feb 03, 2013 | Apple iPod Audio Players & Recorders
My apple 30GB has sad face /www.apple.com/support/ipod
Hi, you may want to try reset your iPod: 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Regards, Peter
Jul 31, 2010 | Apple iPod MA446LL/A MP3 Player
My Ipod Video 30 GB shows a sad face. What do i do?
It looks like there is some kind of software problem with your iPod.
First, power up your iPod (showing the sad face). Try pressing the center and menu buttons at the same time, and holding it like this until the iPod shuts off (after about 5 seconds). This should 'force-restart' the iPod.
If this doesn't work, plug your iPod into your computer, open iTunes, select your iPod in the left-hand menu and click Restore. Note that all songs/photos/videos will be erased by this procedure.
Should this also fail, you can try leaving your iPod turned on (with the sad face), and wait for the battery to completely run out (the iPod should not turn on at all anymore). Leave the iPod unpowered for about an hour, recharge it, and retry the above steps.
Hope this helped,
tS
Dec 10, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod touch speakers wont work
You may need to reset
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 02, 2009 | Apple iPod touch
Ipod touch 2nd gen, speaker played for 2 day,
go to the apple store or call apple. the should replace it for you for free.
May 13, 2009 | Apple iPod touch
Ipod shows sad face and folders
the sad face means there is a software / hardware side fault witch needs service.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
If they dont work you will need to send the ipod in for service.
Apr 19, 2008 | Apple iPod 4th Generation MP3 Player
IM SAD TO SAY BUT YOUR IPODS HARDDRIVE MAY HAVE CRASHED
Mar 18, 2008 | Apple iPod nano
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod 4th Generation MP3 Player Logo
360 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
