Question about Belkin F1DG102U 2-port KVM Switch
Problematic switching between 2 P/C
I use the F1DG102U switch. When I power on the first PC (win vista) all is well. When I power on the second PC (win xp professional), although I can hear the booting up procedure nothing appears on the screen unless I press one, two or even three times the restart button of the PC, in which case the PC repeatently restarts and finally gets in working order.
From that point on everything works perfectly and switching between the two computers is accomplished either using the romote button or the Flip software.
Any suggestions ? Thank you very much !!
  • 1 more comment
  • Anonymous Sep 11, 2008
    Has anyone figured this out? I have the wireless version, but the same thing happens to me. For no reason that I can see, it will switch between computers. Sometimes just once and then sometimes, back and forth several times, until I have to shut off one of the computer to get it to stop.
  • lteads Oct 29, 2008
    same problem but when the laptop (xp) comes up the keyboard does not function or I get an out of range message on the monitor.
  • Anonymous Oct 30, 2008
    same problem.
    i can't get second pc working
  • 31 Answers
SOURCE: Belkin Parallel AutoSwitch F1U115E
Please advise of further info. All the connected PC's are running on XP. One is not connecting to the network. Sounds like the "Local Area Network" setting needs to be set for "Automatically assign an IP". Go to the start menu, select "Run" and type in "CMD". Type "IPCONFIG" and enter. This will display your network setting and IP address. If there is no IP address, then you will enever have a connection. If the IP address is listed, it will display a unique IP address, a subnet of 255.255.255.0 and the ip address of the gateway. Please respond with any further.
Posted on Jun 06, 2007
SOURCE: kvm switch won't stay on second computer, switches back
You might try disabling any power saving schemes in use on either computer. The KVM (I believe) gets its power through the ports and one computer may be shutting down power.
Posted on Sep 01, 2007
I got a new KVM switch and it works great. TRENDnet TK-207K
Posted on Sep 07, 2007
sandrew
  • 2961 Answers
SOURCE: XMLHttp/00413E6C
this must be a troja or a virus and the mesage that pops up bears no relevance as XML is a exel type file along with a HTTP address number.
Click start>run, then type msconfig and in the next window, look at the startup tab and look in the list for anything that relates to XML and untick it.
Click apply and then reboot the pc and then click don't show again when a windows pops up and says that you have changed system settings.
The notification should not now pop up.
Posted on Oct 14, 2007
SOURCE: Help please
change private lan in modem or router and then try again. 168 is being automatically assigned by one of those devices
Posted on Dec 09, 2007
One computer is allowing the keyboard and mouse to be usable while the other is not. This problem happend about a year and a half ago and didn't come up again until I moved to a new warehouse and now it's...
remove old drivers and update them with new one by following this link
this allows you to use additional options....
http://tinyurl.com/f1dg102uuk
also you can download the quick installation guide found in the link above....
Apr 20, 2010 | Belkin F1DG102U 2-port KVM Switch
Satellite A205 hang on AC power in Vista, Win7 but not XP?
Probably you will have to upgrade your drivers, specially power management.
Mar 12, 2010 | Toshiba Satellite A205-S4617 Notebook
Power light went off
No, the switch is powered from the keyboard connection on your computer.
Feb 01, 2010 | Belkin F1DG102U 2-port KVM Switch
Broadcom wireless adapater doesn't power ON with switch. DriverOK
go to hp.com choose downloads put in model# dv9000us laptop scroll down to wireless downloads choose vista then: broadcom wireless download vista driver
Aug 30, 2009 | Acer Aspire 5040-3947 Notebook
I installed a win 7 beta version on my pc..and when i wanted to revert it into vista again it won't install anymore to any os except win 7. When i tried to install vista it cannot detect my HDD, and when i...
To make sure you install back again your Windows Vista and Windows XP is this.
First:
  1. Go to Bios Setup and change the setting of your Hard Disk drive from Sata to IDE mode.
  2. Boot priority the CD/DVD Rom to run your Bootable CD/DVD.
This setting are quietly working, good luck!
Jul 29, 2009 | Computers & Internet
New Lenovo Y430 keyboard and touchpad does not work
Finally, I decided and insisted on being given a replacement for another defective Y430 unit. I am just so glad that the problematic 2 units were discovered before the 7-days allowance for return/replacement of defective units. I now have this third unit of Lenovo to replace the first two defective ones. I do hope this works well and will not make me do a fourth trip to the seller for any returns/ replacements/complaints again. :)
Jun 10, 2009 | Lenovo IdeaPad Y430-5243U Notebook
Windows vista switch to xp
Basically the same way that you installed Vista from XP, but this time you are reversing and Installing XP from Vista.
Feb 18, 2009 | Acer Aspire 3680 Laptop
Audio with KVM switch
Check that the audio-cables from the "other" computer to the KVM are not near anything "bad", such as AC adapter for the speakers, or close to any speakers.
If you temporarily connect the speakers _directly_ to the "other" computer, does the "noise" go away?
Nov 11, 2008 | Belkin F1DG102U 2-port KVM Switch
How to stop win vista firewall and how to create connectivity computer to the switch
... try to also use the domain name ... user_name: user@domain
Jun 29, 2008 | Computers & Internet
Belkin F1DG102U 2-port KVM Switch Logo
106 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
