Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
IPOD NOT DETECTING ON ANY PC XP
MY I POD NOT DECTING ON ANY PC/LAPTOP THROUGH USB
    President:
  • 4,402 Answers
MP3 Players can connect to PC
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall, reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfixIf that doesn't fix it try the USB cable
Posted on Jan 25, 2008
What are the necessary steps for operating the I-pod in conjunction with the computer> Thanks
Use the charger cable the ipod came with and plug it in to a USB port on a desktop or laptop pc. Go to ITunes.com if it doesn't pop up automatically. Import the files you want from your pc to iTunes then sync those files to your ipod. Theyve made it easier to use in recent years
Nov 05, 2014 | Computers & Internet
How do i put music on my i pod
you the itunes software, the usb cable and a pc or laptop
then you need to add songs to the itunes library and export it to the ipod
you can add songs from your cds, from mp3 files and obviously from itunes store to the itunes library
there are several tutorials in the apple ipod support website
Mar 28, 2011 | Apple iPod nano
I-tunes doesn't recognize it.When i connect the i-pod classic 120 gb i-tunes does not recognize the i-pod to sync music.
try first manually resetting the ipod. do this by holding the select button, which is the center button and the menu button,the up button, for about 5 secs or until you see the apple log then release both keys, then re-attach to usb cable, see if it can be detected by itunes,if still not, try using other usb cable or relocate to other usb port on your pc or laptop, for more information check here... http://support.apple.com/kb/ts1369
Jun 02, 2010 | Apple iPod classic MP3 Player
Trancend pod not detecting
Go to Settings->USB
Under USB, you can see two options like, USB and MTV. Select USB.
Now Try again, it will work.
Cheers...!
Mar 15, 2010 | Transcend T.sonic 850 Digital Media Player
"Lost" all USB ports on win xp laptop after plugging ipod shuffle
go into the system restore and choose a date when the usb ports were working then let it go thru its process of restoring. It will restart and then test the usb ports then, if you still can't get them to work then that means the motherboard is bad.
Jun 30, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
When i am attaching any usb device its decting as unknown device and gets stuck.I had reinstall windows and drivers but same issues.
install the chipset drivers of your motherboard and check and i believ ur using service pack 2 of windows xp
a good rating plz,,best of luck,,keep me posted
May 16, 2009 | Gigabyte Giga-Byte:...
I dont have the computer that I orginally synced my i-pod with.
YES SHUT YOUR I POD OFF, THEN CONNECT YOUR USB CABLE TO YOUR PC AND TO YOUR IPOD THEN HOLD THE POWER AND HOME BUT UNTIL YOU SEE THE ITUNES ICON AND THE USB CABLE RIGHT UNDER IT ON THE IPOD SCREEN AS SOON AS THAT POP'S UP LET GO AND IT SHOULD SYNC INTO ITUNES, IF YOU HAVE NO PC THEN YOUR WELL OUT OF LUCK.
RATE ME PLZ
May 02, 2009 | Apple iPod touch
Tevion 4GB MP4 player compatible with I-Pod accessories???
I dont have an ipod to compare it to, but I thnk that ipods use a dock connector, the tevion mp4 player has a mini usb, the kind you usualy find on a digital camera. I might be wrong about this, as there are different types of ipod, so there might be ones that also have usb connectors as well.
Any accessories you purchase have to be designed to plug into a mini usb, so just make sure you check what type of connections your accessories have before buying them.
Alternatively, there are adapter cables out there, ipod docking ones to usb, and usb to mini usb, so it would be possible to rig connections up, they wouldnt look pretty though.
Nov 21, 2008 | Audio Players & Recorders
Mini ipod freezing showing charger sign
restart your pc press del key in your keyboard,
go to setup usb settings disable usb 2.0 setting
Sep 15, 2007 | Apple iPod mini M9160LL/A MP3 Player
İpod nano not seen at explorer and itunes
- check the cable - check the connections on the bottom of the ipod for bent pins, or dirt - make sure ipod battery is fully charged - if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though. - check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager) - uninstall usb ports on pc, let pc redetect them
Aug 25, 2007 | Apple iPod nano
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
35 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
