Question about Kenwood Audio Players & Recorders
Kenwood KR V8070, Cable question
Hello Helpful Tech Support staff,
I recently purchased an HD TV, I need to know if I can use a component cable or will I need to use an RCA cable to connect the TV? I have an installation scheduled and will need to purchase the cables before the installation time.
Thanks for your assistance.
David
  • 6 Answers
SOURCE: cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Posted on Jan 09, 2008
SOURCE: Cable Box compatibility.
my cable box want turn on
Posted on Jun 20, 2008
SOURCE: i purchased a SANYO-DP46848 42"HDTV.
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
Posted on Jul 28, 2008
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
SOURCE: Can't get video via HDMI
Go to here
will tell you how setting Video output
Posted on Nov 12, 2008
Hello could you please answer a question for me--is my 50gx49b hd compatable to watch hd channels-i just gotan hd box but the hd channels are all colors and lines -Thank You for your help Jim
change the hd output to 720p if that doesnt workt hen 480p othwerise your tv cant do it. if you are using hdmi try using component cables. also if you are using rca cables red white and yellow that is why
please let me know
Mar 17, 2011 | Hitachi 50GX49B 50" Rear Projection...
I won a rca scenium 52 inch hd tv.. i hit somthing on my remote and now i have a fuzzy scree. and dont know how to fix it.. i trouble shooted with dish network. they say it is my tv. but the dvd player is...
Hello. I do hope that you have gotten this resolved. But if not, here are some simple steps.
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable- the TV needs to be on an HDMI input
If you are using component cables-the TV needs to be on a component input usually
If you are using RCA cables-the TV usually needs to be on a VIDEO like Video 1 or2
If you are using coax cable-the TV needs to be just on channel 3 or 4.
Becki Barned
DISH Network Customer Service
Feb 12, 2011 | RCA Scenium M50WH187 50" HDTV
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Color fine with rca jacks but when using hdmi/component its not
There may be a number of problems that are causing your HD issues. They may exist in your TV, or in the box you use to tune your channels. Contact your cable or satellite provider and ask them to change out your box. If the condition still surfaces, then you need to have your TV checked. The component and HDMI jacks are both connected to the same electronics. This is why they are exhibiting the same problem.
Jul 15, 2009 | JVC AV-56P575 56" Rear Projection...
Is tv an HD tv
Yes, mostly all new displays are at least 720p which display a great picture ! However, coax cable is the worst possible cable you can use. Your best bet for HD from the cable box is to use component cable. These are the 3 RCA type colored cables, red, green and blue. You will also need another two RCA cables for the audio, which is usually red/black or red/white. If you have a surround sound receiver, then you will not need the 2 for audio to the TV. These 2 would goto the receiver or you can use a better digital coax or optical cable for audio.
Also, HDMI from the cable box to display is a more expensive cable which will give you HD but doesn't always look better then component on some HD cable boxes.
Mar 11, 2009 | Philips Televison & Video
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
I recently purchased an xbox, but because of the cable box, i dont know to to get video
Your cable box and TV should have RCA input jacks (Red, White, and Yellow) Red & White are for Audio and Yellow is for video feed...
HD Receivers & HD TV's are just slightly more upgraded with better video feed connections.
HD video can use three color coded RCA jacks for the video feed or a HDMI cable; if you can use the HDMI connection on your TV I recommend using that because it's less confusing to plugin the input cables. Try turning your TV to it's side to see what inputs you have available to connect your device to.
After you have it pugged your device into the input jacks press the "Input" key on your TV remote and power up the device.
Most TV's have more than one input, so you may have to cycle through the TV inputs by press the input key again until the video feed is displayed.
(If you don't have a "input" button on the TV or remote control you can try entering channel "00")
Nov 28, 2008 | RCA T09081 9 in. TV/VCR Combo
RCA L32WD22 diagonal hd lcd
I had a simliar problem with my xBox, and I own the same TV.  There is a special converter box for the xBox that I recently purchased from a friend of mine.  It converts the signal from the xBox to 720p.  You hook one end to the A/V OUT on the xBox, and you run component RGB and RCA cables for video and sound to your TV.  It now works GREAT!  Perhaps if you searched online, you could find a similar apparatus for the PS2.  Good luck, man!
Sep 29, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
93 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
