Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-w50 zoom not working
I can turn on the camera and take pictures as long as I do not use the zoom. If I try to zoom in, the error message will appear asking me to switch off and on.
  • tmeisinger Nov 20, 2008
    I tried the pull and twist, that didn't work. This is the second time it has happened, the first time Sony covered it. Now it is out of warranty. Do you have any other ideas? What causes it?
  • 74 Answers
Switch on when the lense extends take the end of it and gently twist and pull the lense you may hear it click be gentle do not force it then switch off and on again and this will solve the problem 98% of the time.
Posted on Oct 17, 2008
Manual zoom does not work when I try and use it
Most likely the motor mecanisim was damaged when you dropped it. was unable to locate a sony dealer in nepal, You could try Sears if there is one in nepal.
Hope that was helpful.
Nov 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Zoom problem
sitch on when the lense extends take hold of the end and gently twist and pull the lense you may hear it click. be gentle do not force it then switch on and off again this should solve the problem
Jan 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot w50 zoom problem
Take it to a warm place to thaw out then try. If no joy then assume it has broken. If broken then it is not likely to repaired at reasonable cost - check out Sony for an estimate
Sep 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cyber-shot w50 zoom problems
If this error message appears, turn off the camera and remove the batteries for 30 seconds. Afterwards, reinsert the batteries and turn the camera back on. Perform a manual reset of the camera. Once you perform this it will be back to factory settings and you will lose any pictures stored on your camera.
Aug 26, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Help
If this error message appears, turn off the camera and remove the batteries for 30 seconds. Afterwards, reinsert the batteries and turn the camera back on. If this doesn't work, perform a manual reset of the camera. If you need an online manual here is a link with troubleshooting http://www.docs.sony.com/release/DSCW40_EN.pdf
Aug 17, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-W50
This is what sony cameras do when the lens has become jammed. There are multiple different reasons that the lens can jam but the result is the camera being unable to move it as expected and presenting that error message. Sometimes the lens can be manipulated gently (if extended at all) and freed from the jammed state. Failing this, disassembly is required. Check with your manufacturer for warranty service status and recalls. If they will not cover it you can find a repair provider online. David Millier Advance Camera Repair
Mar 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
81 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
