FixYa.com
Tags:
GE 27GT277 27
One channel fuzzy
posted by newtown on Jan 25, 2008
I have a cable connection. A couple of days ago while changing channels, one channel (52) went all fuzzy grainy on me as if it's a little out of focus. Other channels all seem to be as clear and sharp as they were before. Another TV on the same cable connection has a sharp clear picture on all channels including that one. It appears there is a problem on this one channel on this one TV. Any ideas? Any way to adjust the reception/ focus on just one channel?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 25, 2008
Not Rated (0)
randyleroy1
Rank:Master Master
Rating: 72%, 10 votes
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Standard Televisions problems?
Parental Control Lock
I bought this tv at a moving... Answer This...
SKY REMOTE CODE
i just got a lg model number... Answer This...
twww.florinzdr@yahoo.com
2sk1271 problem, power source Answer This...
GE 27GT277 27" TV
GE TV loses sound after 1-2 min...
I just purchased a used GE... Answer This...
GE 27GT277 27" TV
Auxilliary
Tv will not switch between... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
