FixYa.com
Tags:
Brother DCP-8040 Copier
Showing wanting new drum ?
posted by gaggsy on Jan 25, 2008
after fitting new drum machine still asking for a drum
any ideas Cheers Gary !
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 26, 2008
Helpful (85)
alainski
Rank:Wiz Wiz
Rating: 82%, 24 votes
Hi Gaz,
Here's the procedure to reset the drum.
- Open the front cover, and then press Clear/Back
- Press 1 to reset.
A downloadable user manual with the procedure mentioned above can be downloaded at the link below.
http://tinyurl.com/36slcd
fixya!
Rating Locked! (?) gaggsy has rated this solution as Helpful
Can you Help with these Copiers problems?
Copiers
changing defuser drive gear on...
a spring was laying inside the... Answer This...
Copiers
Scanner Fault
When I power up, the machine... Answer This...
Copiers
Document Feed
Please help, my Panasonic... Answer This...
Copiers
minolta
minolta ep 1030 copier paper... Answer This...
Copiers
project
How did the project with the... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
