Question about Insignia IS-LCDTV32 32 in. Television
My tv says no signal
When i first got my insignia tv everything was working fine and i have cablevision now when i turn my tv on it comes up as no signal i tried a lot of things wat should i do to get it to work
  • sfish432 Oct 15, 2008
    The no signal
    Video 7 HDMI-DVI
Tak a dump
Posted on Oct 05, 2008
  • 52 Answers
Is it in all mode, eg. TV, A/V and other sources? if it does, then you have a faulty main pcb board. claim warranty if still covered. have quote from where you bought it. they must have repair service.
good luck.
Posted on Feb 07, 2008
Samsung, cablevision and tivo - weak or no signal message
With the TV remote you must select which signal input that you want to watch. You can have a TV cable, an HDMI plug, AV, and component, all connected at once and watch the one that you want to. After you select which ONE that you wish to see displayed on the screen, you will have to use the remote for that device
Feb 03, 2018 | Televison & Video
Insignia 26"LCD TV "No Signal"
Your description pretty much narrows it down to tuner failure. I have had experience with Insignia products so not surprised.
Mar 03, 2017 | Insignia LCDTV26 26 in. Television
Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
May 31, 2009 | Insignia LCDTV26 26 in. Television
Does my Insignia come digital cable ready or do I need a convertor box?
Cablevision is forcing people to having to buy Digital Cable Boxes with decoders in them.. On top of what you are already paying you have to pay lets say 2- 6$ per tv for a box per month.  Cablevision is doing this and charging more.  It's really to bad.
May 06, 2009 | Insignia NS-LCD19 19 in. LCD TV
Insignia LCD HD tv with "No Signal/VGA input"
With the model# and date of manufacture I, or others might be able to help better.
• Generally, Most of the insignia TV's are manufactured by Lucky Electronics and have some amount of problems on the main board. The power supply filter is likely drying out it's capacitors as they use caps that are to close in rating to their actual voltage. IE 25 volt caps in a 24.5 volt circuit.
(We replace them with 35 volt.)
This causes flakey actions. Try unplugging the set for an hour, and try it again. It may work, but for how long? IF it works, you should replace all the caps in the power supply area, about 10. You can be sure that one is bad if it is swelled up, dome shaped on top, or hot.
Apr 03, 2017 | Insignia 37" LCD Flat-Panel HDTV
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
Insignia 32 in LCD TV: no signal
No signal.does it means in all modes...tuner, A/V and all other sources. If it does, you may have a faulty main pcb board. Call a technician.
good luck.
Jan 25, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
1,684 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
