Question about Kitchen Ranges
Window to my oven door is broken
Kitchen aid window door#9781721, what is the cost of new glass window...
  • 2 more comments
  • hellojello Jan 25, 2008
    THIS INFORMATION THAT YOU'RE GIVING ME WILL I BE CHARGED FOR THIS
    is there a charge for information
  • worcester Feb 12, 2008
    MY PARKINSON COWAN GAS COOKER MODEL SIG554WN HAS A BROKEN FRONT GLASS DOOR WINDOW. HOW DO I GET ANOTHER ONE AND HOW MUCH THANKS
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    The part for your oven door comes as a kit and costs $208. I cross referenced it with the part number you provided. If you can provide me with your model number (located near the oven door or lower drawer openings), I can see if I can find the window as a separate part and reduce the cost. However, this also makes the repair a bit more tedious. Oven doors are notorious for having a lot of parts and can be a nightmare to get back together if you aren't careful. Do you still have an active warranty? The glass should be covered against breakage. You may double check your paperwork just to be sure. Let me know.
  • 5,911 Answers
No...that's only if you go through chat sessions. I don't charge to give people advice.
Posted on Jan 25, 2008
Kitchen aid oven /range model # kgrt607hbl4
The "window" is comprised of two sheets of glass enclosed by a metal band. Heat expansion results in a less than perfect seal and admission of material thrown off by cooking. It is not practical to attempt cleaning it.
Jun 25, 2014 | KitchenAid Ovens
Broken glass on oven door how to replace it
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Feb 04, 2011 | Maytag MGR5775QD Gas Kitchen Range
Describe your dacor rsd30 new oven door Problem - the glass is broken in the window
heatman101
Nov 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
Broken glass in oven door
The inner glass panels are still available and replaceable.
Cost about $45.00
Mar 08, 2009 | Magic Chef CER3725AA Electric Kitchen...
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Ranges Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
