Question about Dual XDVD8181 Car Video Player
Parking wire is the yellow parking wire going to be hooked up to the ground or the positve side of the parking break
  • parmad39 Jan 29, 2008
    the code did not work. I grounded the parking wire to the ground of the radio harness and worked without a code. Thanks for the help !
There is a factory overide code so you dont have to connect that park brake wire to anything. check blogs and i will see if i can remember it.
Posted on Jan 27, 2008
6ya staff
SOURCE:
I need a FREE 1992 Toyota Camry taillight wiring diagram. My side rear park lights come on but my park lights that work with the brake lights don't. I changed the bulbs and tested everything. I narrowed it...
brown wire is your park LT yellow Left-turn green right-turn. Now the break light my be on it own wire it is red black is ground. but if you have a test light see if the brown wire turns on the test LT when you turn on the park LT or what wire light up when you step on the break pedal. and so on.
Feb 25, 2010 | 1992 Toyota Camry V6
How do i by-pass the pb wire on clarion nz-409 in dash unit so my dvd player without damaging the goods
absolutely not......you run the parking brake wire to toggle switch positive and run the negative to a ground.
Dec 18, 2009 | Clarion Car Audio & Video
How to install a iva-d310 from alpine
The yellow/black wire is for the foot brake and the yellow/blue is for the parking break. These wires need to be hooked up in line with the pinch connectors to the correct wire. The yellow/black wire needs to hook up to the wire to the foot break lead wire before the switch and the yellow/blue needs to hook up to the lead wire before the parking brake switch. This is a sefty feature to deactivate the video display because it is illegal to have video in the view of the driver while the vehicle is moving. These wires are used to tell if the car is stopped.
Dec 06, 2009 | Alpine IVA-D310 Car DVD Player
Bypass parking break for DVD player
It depends on the dvd player, most just need that wire to be hooked to ground. some units, you have to unhook it and reconect it every time you want to watch video. some you have to go on off, on off. The easiest way to bypass, is to get a togle switch, hook one side to ground, hook the other side to your dvd. then you can just flip the switch to make the dvd think you have engauged the park brake. hope this helps
Aug 21, 2009 | Car Audio & Video
I have a alpine cva1003 and cant get the screen off safety mode to play the dvd's. I have the parking break wire from the radio, which is yellow and white connected to the single parking break wire. is...
In order for the video to work you need to hook up both the parking and the foot brake leads so you would have to press in the foot brake pull the ebrake let up on the foot brake then the video should come up but if u want to watch videos all the time moving or stopped youll need to do some custom work so:
Short of making a microprocessor to do the sequence the easiest way is the two switch method. just mount two switches together and do the sequence.
Although the idea of only one switch and the foot brake hooked up correctly might work too.
The best way to go about it is to hook up the system as is should be and use a voltmeter to see what voltage changes are on the lines. Then hook up the switches accordingly.
hope that helps!!
Jul 16, 2009 | Alpine CVA-1003 Car Video Player
I have a 1959-1962 Honda C102 Super Cub 50cc Scooter, with electric start, that has a 6 volt system, that I am trying to get running. I have a new 6 volt battery, fixed a lot of wiring problems, and was...
large wire off starter will go to positve battery, the small yellow/red wire should go to the starter solenoid, and the battery should be hooked up like a nornal setup please rate -jeff
Sep 01, 2008 | 1995 Honda Civic
Parking brake
Parking Brake Lead (Yellow/Blue) Connect this lead to the power supply side of the parking brake switch to transmit the parking brake status signals to the IVA-D310.
Mar 04, 2008 | Alpine IVA-D310 Car DVD Player
No Instruction sheet
This should help you!
As for the remote - see if the cable is hooked up to the readio or modulator. If so press the reset on the back of the remote.
Dec 28, 2007 | Jensen CH6001 CD Changer
Anyone disable the Parking Brake?
Yes, I did it to mine, Just ground it and it will always be *Parking Brake mode* and you can .... You know. :)
Dec 22, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Dual XDVD710 Car Video Player
all you have to do for you to be able to play video while driving is... take the yellow wire with blue strip and wrap it with your ground wire and connect the ground wire to a GOOD chasie ground
Sep 13, 2007 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Larry Tezekjian
Larry Tezekjian
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
