Question about Jabra BT8010 Wireless Headset
Trouble after installing firmware
Hi all, i just got my BT8010 and it was working fine. but after i downloaded the control centre and the firmware symphony-1-40-0the device is just not responding now. i really need help on this
  • 1 more comment
  • jpjoon Apr 08, 2008
    havin same problem here too
    I locate in Korea to purchase bt8010
    talk to the person in Jabra support team and they are asking to come to statedto exchange.
  • Anonymous May 29, 2008
    same here :(, bought it just a month ago, so hopefully it can be solved or replaced but it still sucks :s
  • a320sean Jun 26, 2008
    I too have had problems since updating the firmware. The BT8010 will show 'Charging...' whilst charging but otherwise does not show anything on the display nor will it connect or work in any other way.
I had the same problem before I even upgraded the firmware, it showed up after I selected "delete all" in the paired devices menu. I upgraded my firmware to try to the problem but it didn't help but I did come up with a fix thats worked twice for me. so heres the fix i use  1. delete the pairing on your mobile phone.  2. switch on the headset then hold the on switch in the pairing position for about 7 sec. which should put it in pairing mode.  3. do a search with your mobile phone for a new device and it should show your headset 4. pair with it like normal
after pairing my headset's display always comes back on and then operates like normal  hope that helps
Posted on Jun 28, 2008
  • Anonymous Jun 28, 2008
    I had the same problem before I even upgraded the firmware, it showed up after I selected "delete all" in the paired devices menu. I upgraded my firmware to try to solve the problem but it didn't help but I did come up with a fix thats worked twice for me. so heres the fix i use  1. delete the pairing on your mobile phone.  2. switch on the headset then hold the on switch in the pairing position for about 7 sec. which should put it in pairing mode, (of course you won't see anything on the display but it will go into pairing mode if you hold the switch) 3. do a search with your mobile phone for a new device and it should show your headset 4. pair with it like normal, and it show be back to normal after cycling it off then on.
    After pairing my headset's display always comes back on and then operates like normal hope that helps!
Guys, i had the same problem but i managed to fix it. This is what i did, I downloaded symphony-1-33-0.dfu and symphony-1-25-0.dfu. First I tried to downgrade it to 1-33 but the same problem occured. I then downgraded the set to 1-25 and it worked. I had to do the pairing again. I will now try to upgrade it to 1-33 up to 1-40.
Posted on Jun 27, 2008
6ya staff
SOURCE:
Can't find anywhere the bt8010 software
Bluetooth headset hbh-iv840 sony ericsson doesn't work with my ipone4s to lisen to music, can someone help?, plssssssss :)
Feb 05, 2013 | Jabra BT8010 Wireless Headset
6300 dead no pawar
First of all please check if the battery is in good condition.
If the battery is fine and the phone is still not switching on, then the firmware of the phone should be corrupted. You will have to flash the phone to a latest firmware. Its best to get your phone flashed from a service centre. However, you can flash the phone yourself. Step by steps instructions are given below:
1. Download navifirm from here.
2. Select your phone model and download the latest firmware available.
3. Download JAF from here.
4. Flash your phone with JAF using dead usb option. (How to flash with JAF)
Your phone should work fine.
Hope it helps. Thanks for using FixYa.
Jan 09, 2011 | Nokia 6300 Cellular Phone
Am not able to switch on my nokia x3 mobile
Hope it helps. Please rate the answer. Thanks for using FixYa.
Jan 09, 2011 | Cell Phones
How to program number in bt8010
Download control center program and then go to phonebook icon where it will allow you to manually add numbers; then transfer to phone via transfer tab.
Oct 16, 2009 | Jabra BT8010 Wireless Headset
I just got this bt8010 have no idea how it works
You have to install the Jabra Control Center, and it will take you through the steps.
Sep 26, 2009 | Jabra BT8010 Wireless Headset
After pairing with my mobile (Nokia N73) I am able the listen to music only for 10 sec
Try pairing your device to another mobile and try listening music with it.If it works, either the settings on you Nokia N73 need to be changed, either is not fully compatible with the phone.As a last resort you can reset to default the settings on your mobile.Upgrading the firmware I do not recommand doing it, even from an official site, cause it can turn be very unstable.
Sep 02, 2008 | Jabra BT8010 Wireless Headset
Jabra bt8010
Obvious it's a software problem.I strongly recommand downgrading from the OFFICIAL SITE or a trusty one the previous version that you had before or you could try 1.3 1.2 untill you find a working one.
Jabra BT8010 doesn't power up
Contact me if you are interested to sell it for parts acidx0 ~(at)~ gmail.com
Aug 09, 2008 | Jabra BT8010 Wireless Headset
Lg SHINE CU720
I have a LG VX8300 cell phone and it works fine with my Jabra BT8010. It also connects fine to my Dell XPS m1210 and my Motorola cel l as well. Hope this helps someone.
Feb 18, 2008 | Jabra BT8010 Wireless Headset
Jabra BT8010 Wireless Headset Logo
460 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
