When it gets extremely cold outside and the glo warm reaches its set temp, it not only shuts off but the pilot goes out too and I have to relight the pilot which is also a headache at this point.
we just hooked up a glo warm heater and it keeps shutting off by itself.we even tried lighting it manually.we just hooked up a glo warm heater and it keeps shutting off by itself.we even tried lighting it manually.
Mine don't have a set temp but it just randomly shuts off everything does. I have lived here for about 5 years and never had a problem with it. Then when I went to get it going this year it started doing this. At first I thought it was just contaminates in the line but I know I have had it running long enough that it has cleared the line.
the regulator IS not only the issue, but it's a major safety benefit,..the pilot flame is non adunstable..get a cheap regulator(like the ones for the outdoor bbq's)
Julie, the problem you're having with your DESA, Gas Glo Warm heater may be the result of a clogged Oxygen Depletion Sensor (ODS) which is part of the pilot. I have included a link on how to clean the pilot and the ODS, as well as the burner, that you can download and print for future reference.
Pressure in your tank drops with cold; you may need to tent it and provide a moderate heat source to keep up the pressure. Just like tire pressure- drops when cold. Thanks, please leave feedback or contact me again for more info if you need it.
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
These are vent-free heaters and use an oxygen-depletion sensor to shut a unit off if there is not a sufficient amount of oxygen available for combustion. It is either doing it's job and you may have to open or crack a window while it's operating.
Having the problem.
Pilot keeps going out?
same as the others, the heater and pilot keep shutting off.
My glo warm heater pilot light goes off when heater goes off.
