Question about Canon BJC 2000 InkJet Printer
Black ink won't print
We have changed the cartridges and cleaned the head to no avail. What can we do?
  • Anonymous Mar 03, 2009
    The same thing is happening here. New ink cartridge, heads cleaned, everything is set. The printer goes through the motions, hear the print head motioning and noooooooooooooooothing appears on the page no matter what process is used.
    I'm using Windows 2000 pro edition. Printer drivers are installed, the Canon BJC 2110 is brand new, never used after years of sitting in the box which is about to be replaced into the box in tiny little smashed pieces.
    It's frustrating as heck to have everything functioning properly, goes through the printing motions and nothing at all appears on the page. Not a single solitary mark.
    Thanks for any help and in the least for reading about my frustration.
    Tony
  • SemaphoreSOS Mar 03, 2009
    Tony
  • 167 Answers
Install black cartridge in printer properties!!!
Posted on Jan 25, 2008
6ya staff
SOURCE:
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
HPS 6500 all-in-one won't print
uh,faulty ink carterige, buy another one & don't forget to remove the clear tape seal..on the carteridge
Feb 09, 2013 | Office Equipment & Supplies
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
Won't print black, prints every other colour ok
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck....
Jun 19, 2011 | Canon Pixma MP500 All-In-One InkJet...
Epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Canon BJC 2000 InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
