Laptop cd dvd drive
I bought an acer aspire 9300 last april. recently my laptop does not want to play or burn cd's. it does acknowledge that there is a disc in the drive but will not play it. what will be causing this
  • conker465 Sep 07, 2008
    This solution worked but the next time the laptop was turned on the drive was gone again?......
  • 118 Answers
Follow these steps
Try cleaning the Drive using a drive cleaner , it must read your cds or dvds now if not call your hardware vendor.
also reinstall your Burning software
try burning CDs if it is not working may be a hardware problem
Good Luck
Posted on Jan 27, 2008
    Scholar:
  • 35 Answers
The issue of your DVD not able to play or burn disks could be related to software or hardware, you need to try few steps to know the exact cause firstly make sure that the disk that you are using is good and it is not a bad media, the best way to figure this out is to use a number of disks and see if the drive is unable to play them, if the drive is unable to play all the disks that you have tried then try these steps below to fix the issue
1. Click the Start button, click Run.
2. In the Open box, type Regedit, and then click OK.
3. Click the plus sign (+) next to HKEY_LOCAL_MACHINE.
NOTE: When you click the plus sign (+) next to a folder, it will expand displaying the folders it contains in the left-hand pane of the Registry Editor. When a folder is highlighted, its contents will be displayed in the right-hand pane of the Registry Editor
1. Click the plus sign (+) next to SYSTEM.
2. Click the plus sign (+) next to CurrentControlSet.
3. Click the plus sign (+) next to Control.
4. Click the plus sign (+) next to Class.
5. Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. On the right side of the window, click UpperFilters.
7. Click Edit on the menu bar.
8. Click Delete, and then click OK.
9. On the right side of the window, click LowerFilters.
10. Click Edit on the menu bar.
11. Click Delete, and then click OK.
12. Click File, and then click Exit.
13. Restart the computer normally.
Note: In few machines you will not be able to find both upper or the lower filters and there would only be one of them available, so please do not worry and follow the instructions and delete the one which is found either the upper filter or the lower filter which is available if you are unable to find both.
Regards
Malik Khan
Posted on Jan 26, 2008
    Problem Solver:
  • 10 Answers
1. This could be due to hardware/software.
2. If you insert a CD into it and can you browse the CD content via explorer? If yes; the CD drive seems to be ok. If no, the CD drive is dirty and needs cleaning or faulty and needs to be changed.
3. If you can browse the content of the CD but the CD will not play, it might be the player software problem.
Let me know how this goes.
  • 196 Answers
Could be hardware or software.
This should be under warranty, so call the manufacturer.
I CAN NOT GET THE CD/DVD TO PLAY ON MY ACER ASPIRE 9300
Hi you would need to open mycomputer. then select you CDRom drive on laptop it usually E may differ though. Then press right button of the mouse or touchpad and select autoplay
Sep 15, 2009 | Acer Aspire 9300 Notebook
Cd/dvd won't play, fix that with a registry fix
goto majorgeeks.com and look at other registry fix programs , like registry restore
Jul 09, 2009 | Acer Aspire 5920 AS5920 Notebook
I have an ACER Aspire 9300. I cannot burn CD's.
random problem with burning of CD's. What application are you running to burn CD's? You may need to check your device manager to make sure you have cd\dvd-rw drive installed. If using roxio or nero, suggect uninstall and reinstall if all looks good. if you are trying to burn a cd by using windows, you may not have correct driver or driver installed even if it tells you that copy is completed
Mar 23, 2009 | Acer Computers & Internet
Wont find cd drive acer aspire 5520
hi .. sir
go and try to open in safe mode .
restart >press F8.
see whether it work's..if not go to the bios setup and see the configuration and sellect . restart > delete . (for bios setup..).
replay me if any problem.. thank u sie. don't forget to fix.
Sep 03, 2008 | Acer Aspire 5500 5570-2609 Laptop
Loosing cd/dvd completely from device manager
check your dvd in bios. is it recognised in bios ?
also try to push your dvd, dvd connection to motherboard might be loose.
Jul 31, 2008 | Acer Aspire 9300 Notebook
Laptop drive
dear sie
computer acer aspire 1360 pc dvd drive dease not book
dvd driver stop working c drive was over laoded and the computer whent in to disk clean and deletelte the driver for the dvd rom i can no longer play cd dvd or use the crw or dvd RW ASPIRE 1360 2.8GHZ
PLEASE CAN YUO HELP LOST THE DISK THAT CAM WITH THE MACINE
YUORs garyfifiled@talktalk .net
Jul 28, 2008 | Acer Aspire 1360 Notebook
Cd/Dvd burner stopped working on my laptop
It could be that the burner has gone out in the drive, this is a common problem. Before you go and replace the drive, it could just be a simple driver glitch, try uninstalling the drivers for the CD drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers. If this doesn't work then you can replace the drive.
Jul 08, 2008 | Acer Aspire 9300 Notebook
Acer aspire 9300 laptop
Right click anywhere on the desktop, open the screen saver tab, click on the power button at the bottom. You'll see a box that reads monitor, set this to never. That should take care of the screen shutting down. As far as the orange light, I'm guessing that's the battery light, and it's time for a new battery.(It should be green and flashes orange when the battery no longer works properly)
Jun 12, 2008 | Acer Aspire 9300 Notebook
Cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Jun 04, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
225 people viewed this question
Alun Cox
David Payne
David Payne
