Question about Car Audio & Video
Car Radio When changing gears or sometimes when taking foot off gas pedal, the car radio cuts out. is this an easy problem to fix?
  • 44 Answers
It sounds like it could be a loose connection. Try to wiggle wires in the vicinity of gas pedal or wires that run above pedals. It could be your foot is jiggling a loose wire that has been run above the pedals.
Posted on Jan 26, 2008
BMW cuts out while driving
My Ford did that, but only once. Engine died, backfired and I coasted to the curb. Restarted and ran fine. Sounds like you have a more severe problem. Scary!
Sep 27, 2012 | 1997 BMW 3 Series
Changed car battery and radio-code will not work to get radio back on. It's worked in the past. Any suggestions?
Hi Diane:
You will need to visit the Honda dealer to obtain it; the radio unlock code is unique for each VIN vehicle, so no one can be offered via Internet.
Simply present the vehicle's VIN to get it; sometimes you have to make any payment to the dealer to request this information.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 16, 2011 | 1992 Honda Accord
How can I bypass the starter in my car(manual trans) so it will start? I had the battery checked and it's fine.
  • If the engine cranks ("rrr-rrr-rrr") when you turn the key, then the problem isn't the starter or the battery.Plan to have at least one person sitting in the driver's seat and one or two persons pushing.Turn off all accessories (radio, wipers, lamps).Turn the key to the "on" position.Depress the clutch pedal with your foot.Put the transmission in first or second gear.Release the hand brake and the foot brake.Note that the people pushing need to get the car rolling as fast as they can. This works best down a hill or an incline.Release the clutch pedal while giving the engine a little gas with the gas pedal once the car is moving about as fast as you can run. The engine should start
  • Jan 12, 2011 | 2004 Acura TL
    Engine acts as though gas pedal is engage after taking foot off of gas pedal. Raved up very high. Little smoke came from engine. Engine stayed in high gear. After cutting off the car and restarting...
    On a fuel injected vehicle, an Above-normal engine idle is commonly a sign of an intake vaccum leak allowing un-metered air into the engine...
    However, the "Very high","little smoke" along with the low antifreeze and the fact that the vehicle will not stay running at an idle makes me suspect that engine damage may have occured, and if this is the case-There is no easy fix, this particular engine[should be a 4.6L] will be somewhat expensive to repair/replace...
    Best recomendation is get into a reputable shop and explore your options with them...
    Jan 10, 2011 | 2000 Cadillac DeVille
    What could be the problem if i can't get my car out of park .I have a 2007 dodge caliber.
    shift lock not releasing and holding it in gear,check fuses,sometimes theres a switch on the brake pedal,that releases it from Park when you put your foot on the brake
    Oct 26, 2009 | 2007 Dodge Caliber SRT4 Hatchback
    Have 2003 monte carlo aux input cutting out
    If the radio itself works all the time then you probably have a bad connection between the aux device and the radio. It could be a cable, or it could be the jack. Depending on that it is in easy fix or a harder one. You can take it to a place that installs car stereo equipment and have them look at it or just tackle it yourself. If you put in an aftermarket radio you will need a wiring harness and possibly an antenna adapter. Sometimes you need other things that interface between the car and the harness as well such as controls for steering wheel remotes and other special items.
    Jul 27, 2009 | Car Audio & Video
    Engine over-run between gears
    This is a very common problem for ford. I have the same thing every day. It is the computer not reading the temp. When it does that just tap the gas pedal.
    Jul 19, 2009 | 1992 Ford Escort 4 Door
    Car dying out while Im drivin it
    you may want to check your injectors.
    Jun 03, 2009 | 1992 Oldsmobile 88
    Car wont stay started unless foot is on pedal
    you can try to see if the fuel regulator is bad,sometimes there will be gas in the air cleaner\tube,it sounds to me that its getting too much fuel
    May 09, 2009 | 1993 Chevrolet Corsica
    Car Audio & Video Logo
    42 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
