Detergent drawer How do you remove the detergent drawer on this machine?? I have tried lifting as you pull out the drawer. The manual states to press a button at rear?? cannot find any buttons. Any help would be appreciated Thanks
  • john1941 Jan 26, 2008
    Sorry, the machine is an AEG/Lavamat 74900. The manual states " press a button at the rear"??? But I cannot locate any button or lever in or around the drawer
  • Anonymous Mar 20, 2014
    needs cleaning out
  • 283 Answers
Sorry I can't respond to questions under the header "'Generic Problem for all washing machines" because the focus it is too broad.
Posted on Jan 26, 2008
    Novelist:
    Champion:
  • 244 Answers
Depending on what washer it is cause it doesnt state ithink your on about a zanussi the switch is to the back and it is a circle in the middle of a rectangle which is about 1.5in inlength and about 3/4in in width press this as you pull th drawer out m8
I am not able to remove my I desist detergent drawer. I have followed the instructions in the manual and video but it does not come off. I am not able to clean it.
1. Open the detergent drawer.
2. Press the release lever (A) on the inside of the detergent drawer and pull the detergent drawer out at the same time.
Jul 10, 2017 | Washing Machines
Water coming out detergent drawer and running down the front of machine when we get to the softener cycle
Try pulling the detergent drawer all the way out. Look for blockage in the outlet at the rear. The outlet holes should be open; if they are, lift the top and look for the hose that goes from the bottom of the drwaer slide to the tub.
Jan 01, 2017 | Washing Machines
I need a manual for Spectra TL3635 INOX washer
The manual doesn't appear to be available online, but you don't really need it.
Remove the drawer by pulling it out, and then lift and pull. Are you sure it isn't marked what goes where? My Whirlpool washer is marked in raised writing.
The detergent is one large compartment that is open at the back.
The bleach dispenser is usually in the middle and is small.
The fabric Softener is full depth, but has a system which siphons the softener out when water is added to it. In other words it is a reservoir that holds the fabric conditioner until needed.
With the drawer removed, turn the machine on to do a small wash. Water will come down on the section for detergent at the very beginning. towards the end of the first fill, another jet of water will come down to add bleach to the already filled machine. After the rinses, when it gets to final rinse, a jet of water will hit the Fabric Conditioner compartment. Get ready to insert the drawer if the water splashes out, or plug the front with a tea towel.
Aug 12, 2015 | Washing Machines
I accidentally drop my detergent lid in the softener tray. how will i remove it ..i tried to open the machine but i dont know how.
If it went in the hole at the back it will come out inside the drum. You may be able to pull out the dispenser drawer and check behind it, usually pull out and lift, or there may be a tab under the drawer to push to release the drawer
May 15, 2012 | Kenmore HE2 Plus Front Load Washer
Water leaking out of detergent dispenser
As you said in the question you just need to check the following things.
*Pull out the tray fully and lift it upwards to remove the detergent holder.
*Clean the dispenser housing and drawer with water if you find any traces of detergent in it.
*Reassemble the tray and push it back to its position.(flush with top).
After checking this you are washing machine will be fine.Thanks for your question.
Jun 20, 2011 | Washing Machines
The soap tray fills with water at the back conditioner section on every run (no matter which programme) and does not drain, so I have to manually remove it and empty it after every load. I also think this...
Remove the detergent drawer by pulling it out and then pressing down the yellow part on the back of the drawer. Clean the drawer fully by hand in a washing up bowl using a mild detergent. Detach the yellow part from the grey part by turning it upside down and push in the clips gently. Clean the yellow part thoroughly. Put the yellow part back on - it just clicks back in place, and push your detergent drawer back in. Do an empty cotton wash at 85C (with no washing powder) to sanitise your machine.
Apr 13, 2011 | Dyson Memory CRO1 Front Load Washer
When i do a wash i always have a build up of water left in the fabric conditioning drawer which refuses to drain away.
Often this a caused by a simple blockage of detergent towards the back of the drawer.
Most drawers lift out to allow for cleaning please do so and also use a cloth to remove any detergent from the back of the drawer housing.
If this does not work the blockage is internal and you may need to run the machine on empty a few times. (Often filling the detergent drawer with boiling water will help)
It is imperative that you do not put any more detergent into the machine until this blockage is removed.
If none of these solutions work, try a shelf bought limescale remover and use as directed on the bottle.
Feb 28, 2011 | Tricity Bendix AW850W Front Load Washer
Cannot open the detergent drawer. It is stuck.
No simple solution other all you can do is try pushing it back in and pull it out. If that fails you will need to force it there is no way to get into it, LG parts are not expensive if you happen to break it.
Apr 16, 2010 | LG WM-2277HW Front Load Washer
Can I remove the detergent drawer in a hotpoint hvl241?
There should be a release tab in the dispenser, push down, pull out
if NOT
Remove the screws along the rear top of the washer,lift the top, remove.
Nov 08, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
170 people viewed this question
Top Washing Machines Experts
