Question about Toshiba 25 PACK DIGITAL STYLUS PEN FOR M200 M4 R10 TABLET PC (PA3316U2PK25)
Toshiba tecra M2 LCD Screen
The screen has a pinkish tinge to it when the notebook is initial switch on then it goes black after a couple of minutes - is the LCD repairable or is it 'stuffed' - any assistance will be much appreciated - Cheers MZW
  • Anonymous Mar 17, 2009
    The same problem
  • andy_segui Apr 02, 2009
    Tecra M2, turns on, screen has some very thin vertical lines, a bit pink, then.... black - plugged into external monitor works fine
    Novelist:
    Champion:
  • 226 Answers
A pinkish tint is indication that the backlight tube inside the screen is not fully lit. But then it goes black - meaning the tube shut down? That part don't make much sense - it's certainly possible, though.
Replacing tubes is pretty surgical so I wouldn't recommend it. Replacing the screen should be pretty darn easy. A good, used screen should be pretty cheap on eBay, so that's where I'd start.
Posted on Mar 19, 2010
6ya staff
SOURCE:
There is a small black dot on the screen. Is there a way to get it off?
if is outside the screen, just an lcd cleaner can take of it.
if is inside the screen, a few small black dot is an "acceptable defect".... if so, there is no way to fix that besides to replace the screen
Apr 29, 2010 | Toshiba Satellite M505S4020 14"...
I have toshiba tecra m2 when i had install the graphics card driver and restart my laptop the lcd screen disappears (blackens) while the whole system keeps runnig and i am using the correct drivers...
hi friend
Press F8 Just after you press the power button.
a window will open select safe-mode use the arrow keys to select and hit enter .then safely restore the computer using system restore.or uninstall the graphics Driver from control panel.the drivers that you were going to install was digitally signed?
this thing usually happens when you install an unsigned driver . click her to know hot to use system restore
please rate me
Mar 05, 2010 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Hardrive won't run, screen is black
Most possible one of your Toshiba Tecra m4 driver is not working properly, but don't worry give me a call at +1 (833) 493-0111 so that i can suggest you the right way to fix it!
Apr 13, 2017 | Toshiba Tecra M4-S435 Tablet PC
Clean dust from tablet pc screen
You have to remove the screw covers (the black squares around the screen), remove the screws and gentley pry the cover open with yor finger nails or a flat head screw driver, but be careful not to dent the sides with the screw driver. You can then take a can of air and blow the dust out. I would not touch the sensetive screen under neath. You could take a anti static, micro fiber cloth to wipe off the tough stuff.
Jan 26, 2009 | Toshiba Tecra M7 Tablet PC
Tecra m7 doesn´t boot up
mine does the samething have you found out what the problems is yet?
Dec 23, 2008 | Toshiba Tecra M7 Tablet PC
Toshiba tecra m2 laptop wont start..
nothing happen when you press power? and when you plug energy no led?
Aug 27, 2007 | Toshiba Tecra M214-XGA (PTM20U0776X7)...
Tablets & eReaders Logo
841 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
