Question about IBM FRU POWER/RESET CARD 73P6310 Power Supply
Zcm5600 cooker the oven and grill keep blowing out leaving gas coming through but no flame. how can i fix this
    Problem Solver:
  • 13 Answers
You may have a faulty regulator or worn burners!
Posted on Mar 13, 2008
I have a kitchenaid model kgrs505xss double oven. The flame in the bottom oven comes on and burns for a very short time, then turns off before the oven comes up to temperatures. What is wrong?
Any gas cooker has a thermocouple that keeps the gas valve open; if the thermocouple no longer generates current (which feeds the coil of an electromagnet) then the gas valve closes and the flame will go out. So check thermocouple. In normal conditions the voltage generate by the thermocouple is low but the current is high.
Nov 14, 2017 | KitchenAid Ovens
Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Oct 19, 2012 | Ovens
Top burners will noty lite
Hello, this is a strange story.
I had this a few times in the opposite and then I found that it was a LPG cooker in stead of a natural gas cooker.
Did you buy this cooker second hand and did not use it before?
When this cooker is normally natural gas, then the nozzles are much larger then when used for LPG, as the pressure of LPG is much higher as for natural gas.
In that case you can change the nozzles for LPG use
Is this a dual fuel cooker with electric oven?
Kind regards, Dik
LPG Jets Cookers Ovens Hobs eBay
Feb 21, 2018 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Low flame and not heating oven
we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
Nov 24, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Computers & Internet Logo
76 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
