Question about Sharp AR-207 Copier
SF1118 I had SF1118 sharp machine Replace developer indication is there after replacing developer indication is still there.
  • Ashish Sood Jan 25, 2008
    can anybody give solution
    Problem Solver:
  • 7 Answers
Clear the developer counter , simulation 42-01
Posted on Jan 26, 2008
    Sniper:
  • 54 Answers
You need to clear the developer counter. Simulation 24-6.
How can I replace developer in my copier?
Wouldn't necessary change the developer, only if it is causing quality issues, maybe your developer light is on, on the machine. Still should be able to use the machine.
Cheers
Mar 13, 2015 | Sharp AR-M207 All-In-One Laser Printer
I have Sharp copier AR-M236 with error code:f2-04, how can i remove this error?
That error is a bad CRUM. Replace developer unit use only Sharp supplies. The chip on the developer unit doesnt match with the machine.
Aug 22, 2010 | Sharp AR-M237 Copier
Need to replace drum and developer maintainance
If you are getting that message and the prints and copys still look good , just do this.
Press # * C * and that will put the machine into diagnostics.
Enter the number 24 and press start, That will get you into maintenance resets. Then enter 06 , press start, then while still in 24, press 7 and it will reset the developer.But 24-06 and 24-07 should clear the count and return the machine to normal. The developer and drum will normally run longer than indicated by the counter.
Jul 16, 2010 | Sharp AR-M205 Copier
How do I replace the drum in this machine?
Pul out the drum unit, dismantle it, replace blade, drum and developer.
After that you need to clear drum counter.
Jun 29, 2010 | Sharp AL 1631 Copier
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
I have changed a developer and so i want to run a sim of developer in the copier sharp ar-5316
Hello sir; This model machine not require developer to replace, it come with toner cartridge therefor no such simulation code.
Jun 11, 2009 | Sharp Office Equipment & Supplies
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier sf 2530
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
Sharp AR-207 Copier Logo
133 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
