Question about Zenith IQB60M92W 60" Rear Projection Television
No picture no sound
The power is on but there´s  no picture and no sound either any suggestions?
  • Zenith Master
  • 5,138 Answers
Replace your power supply broad.
Posted on Jan 25, 2008
No picture but have sound.
Hi Celeste,
I appreciate your efforts so far.You have sound but no picture. Can you see the backlights? Or is there the on screen LG logo? If the logo is not there it means the backlights in your TV are not working. Mostly it is the inverter board which makes necessary power for the back lights goes bad. Good LUCK.
May 26, 2015 | LG Televison & Video
ILO DPD4210, no picture or sound. It appears to be stuck in stand by mode. The LED lights are solid Green or Red. It just stopped showing the picture and sound. Any suggestions of what might be the...
Sounds like an ordinary power supply failure. You just have to desolder and semiconductors that are bolted to heat-sinks and or look for electrolytic capacitors that are bulged or not the correct reading. A lightning strike or power surge could have blown a thermistor.
Oct 17, 2013 | iLO 3200 32 in. LCD Television
Hyundai LCD tv has sound but no picture, any suggestions?
If there is no fuses in the power supply module, then you have
Video/luminance defective module, the voltage to that circuit cames
from the power supply Module.Can you mesure that?
Nov 02, 2012 | Hyundai ImageQuest HQL320WR 32 in....
PH-50T18 Prima The picture doesn' twork. Sound works. any suggestions
There is a power supply failure and this might need attention of a qualified service technician
Jul 11, 2012 | Televison & Video
Pop sound and now no picture or sound still gets power
Try disconnecting all the cables from the TV then reconnect them after a few minutes. It's suggested that you connect the power cable from the TV directly to a functional wall outlet.
If still there is no picture on the TV then it's required to replace the projection lamp.
Sep 08, 2009 | Toshiba 57H81 57" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
No sound or picture
You may have a problem with the switching power supply or the high voltage power supply. Because these two power supplies output hazardous voltages I would suggest that you take this to a shop for repairs.
Oct 01, 2007 | Apex Digital GT2015DV 20 in. TV/DVD Combo
No picture
if you are having sound your problem is on the video circuit or related circuit.if no sound on video no power have your tech check the power supply and related circuit.good luck.
Apr 17, 2007 | RCA F32650 32" TV
Zenith IQB60M92W 60" Rear Projection Television Logo
77 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
