Toshiba 50A62 Remote Infrared Sensor
No remotes will work to power on, change channels or volume. All has to be done from the front panel. I tested the various remotes and batteries (used cell phone to view the infrared signal coming from the remotes).
Looks like the internal receiver sensor (part number is 23000852 behind the TV screen ?) is the culprit ?
Never saw a sensor behind the screen before. I checked a supplier (http://www.tritronicsinc.com/storefrontB2BWEB/index.do?action=i) and they have the sensor for $ 1.55
  • Carl Gogats Jan 23, 2009
    remote does not activate anything on the tv the remote from Dish Network can not find the proper code to operate TV
    Problem Solver:
  • 40 Answers
I have replaced these IR sensors before and it has solved the problem...they dont blow all the way..they just get weak......replace it.
Posted on Jan 26, 2008
  • guy_apcheco Oct 12, 2010
    I went to replace min and the bad one has 4 pins and the new has 3. which points on the board do you solder the pins
The power on/off button on the remote control works but the channel & volume buttons no longer work
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 15, 2014 | Televison & Video
Can't use my remote or the cable remote to change channels or decrease or increase volume.
Sep 13, 2014 | Sharp Aquos Televison & Video
Sanyo DS31590 no remotes will work, will not turn on power or volume but changes channels
If you can control the TV by using its front panel controls, and only remote control is not working, the fault may be either to its remote control handset or to the remote sensor inside. The remote sensor is a small component, having only three solder terminals and will look like this. 7_12_2012_12_53_47_pm.jpg7_12_2012_12_54_01_pm.jpg
This is the component inside the TV which senses the infrared rays emitted by the remote control, and convert it to digital signals, and send to the microcomputer section circuit to process. This component can be located just behind the infrared remote window at the front panel of the TV. You have to open the TV to access it, and to replace it. Just check your remote for its infrared emission, before going further. Just get more details about how to check a remote control from this site named 'Electro-help'. Pull up older posts there. Just check this link, and locate the site named above.
Jul 12, 2012 | Sanyo DS25390 TV
Toshiba 32a14 does not respond to remote control
Hello
There is a infrared light sensor inside the TV which detects the infrared rays emitted from the remote control, when we press each button on the remote control. If this sensor has got damaged, the set won't respond to any remote control handset. The sensor can be located just behind the infrared sensor window at the front panel of the TV. To access it, you have to open the TV. It is a three terminal component, will be soldered diretily to front panel circuit board, of with the main baord itslef. Will look somewhat brownish black in colour. There are so many types can be seen . Just look what type if fitted with your TV.
2_4_2012_6_58_45_am.jpg2_4_2012_6_59_07_am.jpg2_4_2012_6_59_34_am.jpgSee some models infrared sensors. Check out which type your TV has.2_4_2012_7_00_45_am.jpg
Feb 04, 2012 | RCA Televison & Video
Remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Nov 14, 2011 | Televison & Video
Where is the remote sensor for the Toshiba 50A62?
Hello
Remote sensor is an internal component, and can be locakted just beneath the remote sensor window at the front panel of all TVs. It is usually a three terminal black colure component, diretly soldered to a circuit board. In some sets, it will be on a seperate circuit board, and in some otheres it will be soldered to the front panel control switches board. OK.
Mar 06, 2011 | Toshiba 50A62 50" Rear Projection...
TV doesn't respond to the remote control...can't change channels
You have to find out if the remote is sending out the infrared signal to the TV remote receiver or not, you can test that by pointing the remote at the digital camera, you should see flashing light on the camera screen when any one of the remote button is pushed (digital camera can detect infrared light). If get the flashing light then the problem is in the TV remote sensor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 15, 2010 | Hisense TL-3220 Television
Infrared sensor won't work in a Toshiba TV
The remote wouldn't work on my brand new 46" Toshiba TV. Comcast person said the tv gave off an infrared signal that interferred with the Comcast remote.
Solution was to turn on cable box FIRST, then TV ( now I use All On button, which turns on cable first). If I turn on TV first, the remote wouldn't work consistently. Hope this works for you.
Aug 09, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Remotes do not work
You can quickly test the remote in question with a digital camera... please vist my Tips & Tricks so see how.
Jan 23, 2009 | Toshiba 50A62 50" Rear Projection...
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Televison & Video Logo
1,277 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
