Question about Fisher and Paykel GC913 - Stainless Steel Gas Cooktop
Is this a design fault?
Unable to light all more than 3 burners at the same time as it cuts out. It always seems to be the small burner that doesn't light and causes the safety feature to cut out the gas supply. We have had the gas checked twice and the pressure is fine. This is the second hob we have had and the same problem. The engineer has changed all the burners and the ignitors and it still does it. Any suggestions.
  • Helen2408 Jan 25, 2008
    I have no idea what the readings were. I called out Transco and they checked the pressure, regulator and meter for leaks. This is the second hob we have had as F&P replaced the first hob after two engineers came out. When the 2nd hob was fitted the F&P guy found a pressure problem and called Transco who replaced the meter and regulator as there did seem to be an itermitent problem. However it still cuts out so more engineers came out and wanted Gas checked again.....did that...all ok. Engineer came out again this week and replaced all five burners and ignitors put it back together and still it cuts out tho it does seem better than before. It is always the small burner that starts off the problem. I have found that when trying to light the small burner whilst it is clicking if I blow gently pushing the gas into the ignitor spark it will light and stay alight. Sorry to waffle on but it is becoming a real pain in the behind. It is natural gas.
  • 770 Answers
What were the readings and at what points where they checked at?? is this unit Natural or LP gas??
Posted on Jan 25, 2008
  • Gary Davd
    Gary Davd Jan 25, 2008
    WOW.. Sounds like you have been thru the mill on this unit the small burner has just been replaced and still doing this the only other thing I can think of is the pressure regulator on the bottom(rear) of the unit is out of whack the pressure really needs to be checked there ....with all burners on ..and set to High your pressure should read 10.25-10.5 W.C if not something else maybe stealing your gas pressure99i.e dryer , fireplace, furnace)
    Please update this post as i would like to know what happen
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
When I turn any burner on, the ignitors work fine but it takes a very long time for the burners to ignite. Problem is worse the longer the top has been turned off. Once gas gets to the ignitor, it lights...
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Jul 15, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
We have a smooth electric cooktop and the burner that has the option of being large or small only lights up small. What part do we need to fix this?
first check the wiring to the burner itself you might have a burnt connection to the larger one or a bad receptacle if both are good then you would have to buy a new burner try allbrands appliance parts they seem to be cheaper
Apr 30, 2010 | Amana AKT3040 Electric Cooktop
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
Burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
Dec 19, 2007 | Thermador SGS36GS Gas Cooktop
Fisher and Paykel GC913 - Stainless Steel Gas Cooktop Logo
119 people viewed this question
Top Fisher Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Fisher Cooktop Expert? Answer questions, earn points and help others
