Question about Acer AL1912B 19" LCD Monitor
Problem monitor ?
My screen keeps getting shadows and and will what looks like it is spining and shaking it keeps doing this then stops and starts can not read or make any thing out when it happens it seems to be getting worse
  • terry4tmd Jan 27, 2008
    I did not have another computer to try monitor on but i did borrow anouther LCD monitor and the problem seems to have gone wich leads me to beleive it was my monitor could this problem be fix whith up date driver or software. thank you terry
Thanks Eloquinn i will look into it, the rating link did not work i will try again tomorrow
Posted on Jan 25, 2008
  • 3 Answers
This is probably not a problem with your monitor. It sounds more like a problem with a bad or overheating video chip. I've seen very similar problems in the past when a heat sink pulled away from the video chip.
If you can, try plugging this monitor into a different computer and see if you can reproduce the problem on a different computer. If the monitor is stable then the problem is probably your video chip.
If the machine is under warranty then you'll probably want to get it repaired by the manufacturer. If it's a desktop machine then have a new video card installed or replace the current video card. If it's a laptop the. If it's a laptop then you'll probably have to send it back to the manufacturer for repairs.
If you are able to reproduce the problem on a different machine then the problem is indeed your monitor. You'll probably either need to return it to the manufacturer for repair or purchase a replacement.
Screen blue shadows laptop
See if you can set the sharpness a little lower in the monitor setup on the pc, not the monitor first. Then try sharpness on the monitor.
Mar 09, 2014 | Onda Computers & Internet
Shivering screen
Shaking or trembling of a computer screen is often caused by interference from another device that is within a couple feet.
It can also be caused by another monitor close by.
If the removal of these objects does not stop the trembling, the monitor may have built up magnetism and need to be degaussed.
Find the menu button for your monitor.
This is usually on the front of the monitor.
It is sometimes on the side of the monitor.
Push the menu button. Scroll down until you find the screen option.
Select "Screen."
Scroll down to the degauss option.
Select "Degauss."
Select "OK."
The screen will make a tuning sound, as if you hit a guitar string.
The screen will shake and vibrate.
The shaking should now be gone.
If it is not, it will need to be looked at by a professional.
May 04, 2013 | HP Computers & Internet
When i turn on the laptop it shows blank screen only.how can i fix it. thanks
Do you see anything at all such as the boot up logo? can you hear the HDD spining? if you can hear the HDD spining but you see nouthing try the following.
connect an external monitor. Look along the function keys and find one with a screen logo on it press fn and the appropriate F key and it will switch to the external monitor. The switching of screens is normally 3 cycles 1. external monitor on 2. both laptop screen and external monitor on 3. back to laptop screen.
If the external monitor comes on it's the screen inverter or screen at fault.
Once you have confirmed what the problem is we can move on to checking the screen wiring or a screen or inverter change.
Aug 18, 2010 | Computers & Internet
Screen Shakes on High Resolutions
your rate of refresh is too high, it's refreshing too fast, you need to lower the screen resolution. keep in mind, the tv resolution is much much smaller than a computer monitor. a computer monitor has much higher resolution. so Tv can only handle so much in resolution. if you need a better picture, it always the best to buy a monitor, not a tv for computer to get a good picture. if you have any more questions, let me know.
Oct 17, 2009 | Televison & Video
'Shadows' behind all texts and images on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
I have red and green shadow on top and bottom of the screen.
Ur Convergence board is dead or deffective with the IC chip.
Aug 17, 2009 | Akai PTH5498 54" Rear Projection...
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
LG L1520B
This sounds like either a loose lead connection or a corrupt driver, if its looking like a driver fault you can click Start>Run then type 'dxdiag' then hit enter for windows to check drivers. If it's a driver fault unistall driver in add/remove programmes and restart pc, when it finds your graphics card on startup insert your Graphic card cd rom to install driver again.
Dec 16, 2006 | LG L1520B 15" LCD Monitor
Acer AL1912B 19" LCD Monitor Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
