System not shutdown properly
IBM PC windows Xp operating system not shutdown properly
  • 1 more comment
  • vishal_g Dec 14, 2008
    my system not shutdown i have to press down the power button,but yes when i start my system it shows one sceen in the code something "]][" then only OK button,i press the ok then the user screen comes but not able to write down the password so i again have to poweroff and agIN RESTART THEN SOMETIMES the screen not appears and i can wrtie down thje password and starts the PC. Please reply as soon as possible..i facing this problem long time....thanks in advance...
  • Anonymous Apr 24, 2009
    System dosent shutdown / restart /log off even after going through legal process
  • Pascal Willemen
    Pascal Willemen May 11, 2010
    Can you be more specific on your problem. If the error you mean occurs at start-up saying "Windows did not shut down properly the last time" ignore it when nothing is wrong and just boot Windows. This message occurs when Windows wasn't shut down by means such as just disconnecting it's power or holding it's power button instead of going to Start > Shutdown.
    Or do you mean that the system just won't shutdown when you tell it to? I might have an answer for that one as well.
    Tell me more about the problem/answer the above stated situation.
    Greetings,
    DarkNeogen
  • 146 Answers
Try
start>run>cmd
shutdown /p
Posted on Jan 25, 2008
    New Friend:
I give the command of shutdown after sometime my lapy is not shutdown properly
Posted on Feb 20, 2010
6ya staff
SOURCE:
Unexpected shutdown problem
your operating system might have corrupted, try reinstalling window, if problem persists then it might have processor cooling problem, check the fan on processor working fine, or sometimes it can be a problem due to RAM, try removing you ram change it... try again...
Feb 07, 2014 | IBM ThinkPad R40e 2684 Notebook
Laptop doesnt shut down
With xp you a have to select
Start --> the right arrow --> then shutdown.
Aug 27, 2012 | HEWLETT-PACKARD HP ProBook 4420S NoteBook...
I am using XP.. net modem working case if take a long time for System shutdown.. if put off modem immiditly shutdown. how to shutdown if working modem.
Windows Server tries to "gracefully" shutdown.
This implies that any "active" network-connections that use the modem will be signalled to "properly" close. This may take a while, waiting for the "other" end of the connection to respond.
However, if you have no active network-connection, then Windows does not need to "wait" for the "other" end of the connection to respond -- it can immediately close the "severed" connection.
Sep 13, 2010 | Microsoft Windows Server 2003 Enterprise...
Ibm desktop cannot start windows xp But have drive windows. problem windows loading beak down.
try to install another operating system if it show the same problem means it's yours hard drive problem.
Dec 25, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Blue screen on Thinkpad R51e & cannot be shutdown
what operating system are you using and please be more descriptive regarding "blue screen" is it the notorious microsoft "Blue Screen of Death"? or? when this occurs is the system totally locked? or can you hit ctrl alt del and get the task manager? can you boot into safe mode? if you're using xp and can get to safe mode.. have you attempted to restore to an earlier restore point prior to this issue? if yes and you haven't restore back to before issue occured.
May 20, 2009 | IBM ThinkPad R51 Notebook
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Restart problem
There might be possibility of Virus.Please check for virus.
This problem may occur if all the following conditions are true:
  • You have East Asian Language support installed on your Windows XP-based computer and the Input Method Editor (IME) selected as your default input language.
  • You have the Welcome screen turned on.
Check weather you are using service pack 1 or above.
If still problem occur then just try to download Shutdown patch from website
Apr 08, 2009 | IBM ThinkPad R32 2658 Notebook
IBM Thinkpad t60 won't start properly
I think the installation has corrupted some files on your operating system. Try to repair the operating system using the installation cd. That shud fix you problem
Thanks for using Fixya. A Fixya rating is appreciated !
Feb 07, 2009 | IBM ThinkPad T60 Notebook
Acer laptop aspire 4710z config my notebook have problem
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Installing new OS
Every laptop is accompanied by a preinstalled vesion of Windows, on the same hard disk in a hidden space. So if you get a prompt to restore your laptop to a previous state at the beginning of system startup, press the relevant key. If windows xp is your choice. and want to install it you may need follow the installation instruction from your system manufacturer. When the system starts up some information is displayed on the screen, like this: " Press F1 to enter setup" If you press the relevant key and enter the BIOS setup you can find the CPU temperature settings, shutdown temperature etc... This may not be you case. So I suggest you to get support from a qulified technician. Your system hardware should have some problem. (motherboard or hard disk is more prone to error) you can also try to find information from your system vendor's manuals and support website. All the best
Oct 03, 2007 | IBM ThinkPad A21m 2628 Notebook
Computers & Internet Logo
614 people viewed this question
Ekse
Marvin
Marvin
