Question about HP LaserJet 3055 All-In-One Printer
No Paper Pickup
Our printer said there was a jam. we checked everywhere and there was nothing we could see. We removed the ink cartidge, turned it off and back on. Then the message changed to, "No paper pickup."
From this moment we only have the message "no paper pickup".
  • 3 more comments
  • Anonymous May 07, 2008
    NO PAPER PICKUP
  • Anonymous Sep 30, 2008
    I have the no paper pick up problem and followed all your segs. but it's still on. What can I do next to remove it and get my printer going?
  • claudao71 Nov 05, 2008
    when i turn on the print "NO PAPER PICKUP" appears in panel
  • Anonymous Jan 31, 2009
    same thing
  • lileyj Feb 02, 2009
    In checking a little closer there was a plastic piece whish has a small tab that it swivels on. One side was broken off and this is causing the pieces to not work as they should. I am trying to find out if I can just purchase the broken pieces or I have to replace the whole paper takeup unit.
    Does anyone have any ideas for me or locations where I might be able to purchase just the couple parts I need?
  • 55 Answers
Turnoff the printer n reseat the tomer catridge properly ,take care it should not be tilted on side,check it that it seated properly,power on the printer n check ,can u hear any motors moving sound,if yes check the printer now,if not check for any peice of paper inside the printer especially from where the paper comes out
do revert
thnx
Posted on Jan 28, 2008
I have hp laserjet 3050 printer and its giving no paper pickup error on panell i did every things which solution posted on this site. but still error there. there is no paper i checked every where there is no even small paper . any one has good idia to fix this problem
Posted on May 12, 2008
Asd
Posted on Sep 25, 2008
Look on roller behind cartridge.  Most certainly there will be a very small piece of paper stuck in the rollers.  Take it out.  Printer will reset.
Posted on Jan 30, 2008
  • virensharma1 Mar 23, 2011
    Thank you very much ....... there was a piece of paper..... now it work perfect.... thanx 1ce again
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Paper Jam
Remove ink cartidge, undo clips first and give it a tug upwards, you should see the paper. Shut machine & restart.
Jan 10, 2010 | Brother HL 2140 Laser Printer
What is wrong when the second light from the top is blinking?
Check there is not any paper jam. pull the ink cartidge and refix it if you have other ink cartrdge try with it.
Also check in back side of printer there is not any paper jam.
Jul 13, 2009 | HP LaserJet 1320 Printer
I have an error code 5100 on a Cannon MX310 that will not allow me to print. Can you help please?
There are several things to check
1.remove and reinstall the ink cartidges
2. press ON/OFF switch to reset the printer
3. if the printer is new, make sure all the packing material has been removed
4. Check the paper path to make sure that you do not have a paper jam.
5. If these do not clear the problem, you need to have the printer serviced.
2. 3. Remove Packing Material MX310 4. Removing paper jams MX310 5. The MX310 may require repair
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MP470 printer jam error
hi...open the printer then clean..i think theirs a lot of DUST that's why printer said paper jam
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper Jam 2
We had the same proplem - did you check there was no paper jammed when you opened the back cover?
Sep 09, 2008 | Samsung SCX 4200 All-In-One Laser Printer
HP Laserjet 3050 No paper pickup
My printer now spits out the paper all over the place and jams up all the time. Did not happen when I first got my 3050 a few months ago.
Jun 06, 2008 | HP LaserJet 3050 All-In-One Printer
No paper pickup
Hi , I just had a same problem with the HP Laser Jet 3055 printer at our office but I fixed it! try this:
Turn off the printer.
Open the printer door.
Remove the Cartridge.
Look down behind the cartridge, there's a small white roll. Try playing with it. move it back and forth. try emptying the paper tray and place it back in the printer.
Turn on the printer.
I did this and for some reason it worked! GOOD LUCK!
Jan 22, 2008 | HP LaserJet 3055 All-In-One Printer
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Paper jams
It has nothing to do with cartrigdes. You have an undetected paper jam. You need a pair of tweezers and a torch and need to play lets find the nasty small hard to see bit of paper or ujo (unidentified jamming object) i had a piece of toddler toy cardboard so small once i had to remove it from my roller with a pair of tweezers so don't laugh at me!!! Good luck. Make sure you look everywhere, including inside unit, and down the back where paper goes too. Cheers.
Aug 30, 2007 | Lexmark PrinTrio X75 Printer
HP LaserJet 3055 All-In-One Printer Logo
3,246 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
