Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony color TV screen
The color of my TV screen is fadding and it is always showing many green horizontal lines on the screen. what could be the problem
  • sher23 Feb 17, 2008
    My TV suddently went black. I turned it off and then back on. When the picture came back it was very faint and had a strong green hue.
  • Larry  Dillon
    Larry Dillon May 11, 2010
    When you say the screen is fading, is it going dark? Is the green lines trough out the entire screen? Is the screen color green also. Does the set flash a certain color once in a while?
  • Sony Master
  • 5,138 Answers
You can bet your GREEN TUBE is BAD.
Posted on Jan 25, 2008
  • ladywinn
    ladywinn Jan 25, 2008
    your green picture tube is bad .or your video ic and maybe cap.on crt broad.
  • ladywinn
    ladywinn Feb 05, 2008
    Why is it that my reply is rated as inappropriate when mine is the best solution.
  • Sony Master
  • 8,617 Answers
Your green CRT socket may have a solder crack, or it could be the CRT developing a short. You can switch the green CRT socket with the one from the red RT and see if it still flashes green. If it does then its your CRT, But if it now flashes Red, Its a problem in the green drive circuitry.Thts the quickest way to locate exactly where your trouble is. If you need anything further let me know.
6ya staff
SOURCE:
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Fads to green with spiraling lines
you may have a short in the picture tube. but from your description it sounds like the positor has failed. really hard from your description but if the positor has failed its very cheap to replace..farr64
Apr 27, 2009 | Televison & Video
TV screen turns green
i think your color combination chip is not working. you may have to change the chip of color system.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
