Question about Epson Stylus CX6400 All-In-One InkJet Printer
Phantom Foreign Object
My CX6400 was working fine when suddenly I got the red exclamation mark and printer error message on the lcd. I installed the Status Monitor 3 and it tells me there is a foreign object in the printer. I have checked and the machine is clear. It starts up OK and feeds paper properly, but when I send it something to print this error appears. I have cleaned and oiled the printhead carriage bar to no effect. Does anyone have any other suggestions?
  • Anonymous Feb 06, 2008
    Same problem as tricky1962's (Error - Foreign Objects ?)
Lost my program disc
Posted on Jan 25, 2008
Canon mp560 b200 error
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
if its driver related
Click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow question / exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope it helps
Oct 22, 2012 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
I have an officejet 5610 all-in-one inkjet printer. There is an ornage exclamation mark next to the setup between the pound sign and the setup button that keeps blinking. How do I get it to quit. I...
The Exclamation mark is an Attention: error indicator. There is a problem that you need to fix. You need to fix the problem. Was there is any message on the LCD screen when you started having the error?
Press Cancel and try printing again since you apparently cleared the LCD message. The problem could be a paper jam, no paper in the paper tray (or the printer can't pick up the paper), an ink issue or something else.
Please add a comment with the error message for additional support. I need more information to tell you what steps are most likely to solve your problem.
Apr 19, 2012 | HP Officejet 5610v All-In-One InkJet...
The red exclamation mark is lit and display says i need service
It could be that you have reached end of life on the waste pads. The pads will need to be replaced and the unit will need to be reset. Most likely thats what the problem is, you can verify this by going on the status monitor.
Dec 14, 2009 | Computers & Internet
Trhe printer has stopped working completely
just try to do a hard reset of the printer. this iwll solve the problem.
Jul 27, 2009 | Epson Stylus CX6400 All-In-One InkJet...
When turning the power on to my Epson CX6400, the following error message comes up: "Error: Printer Error -> SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESSARY." The little "!" exclamation point...
Sounds like the ink counters need resetting (it happens with other printers as well)
Go here for more info as the prog supports your printer
http://www.ssclg.com/epsone.shtml
Jul 17, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Error light on
try this site and follow it along
http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&pid=C11C545001
its their support link
Apr 26, 2009 | Epson Stylus CX6400 All-In-One InkJet...
When turned on only copy button lit and a red exclamation lighton
Hi
Try unplugging it and check for specks of paper inside the printer, then try to replug it from outlet and turn it back on. try if it will copy then try printing. Hope this helps
Dec 12, 2008 | Epson Stylus RX500 All-In-One InkJet...
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Error message and red exclamation indication
Finally figured out the problem.
1. Took waste pad out and cleaned with paper towel. Couldn't find a replacement waste pad, so needed to clean it instead.
2. Downloaded SSC Service Utility software (free) in order to "Reset the Protection Counter". This is an option within the utility.
Printer must be on when running the SSC utility.
Oct 28, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus CX6400- Error
This worked me:
Manual reset for Epson CX6400
  1. Turn off the printer.
  2. Press and hold B/W+COLOR+STOP button.
  3. Press and release the power button.
  4. Release the B/W+COLOR+STOP buttons. (My screen said "Init EEPROM")
  5. Press COLOR button to clear protection counter.
  6. Turn off the printer by pressing power button.
Found this solution here: http://tricks-collections.com/resetter-epson-stylus-cx6500/
Jan 01, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
