Question about Samsung TS-H492A/RSWN CD-RW/DVD-ROM (Combo) Burner
CDW niether reads ,plays burn or writes CD's DVD works great does not hve burner
My dvd drive is not a burner. It is working plays DVDs good but my CD does not do anything i been told by hp that there are two lasers in product one for CD and one foDVD and my laser for CD is probaly burned out
  • bigpolk Jan 25, 2008
    i have tried many of remedies suggested through hp troubleshooters expert tech chat line none worked he suggested the burned out laser . i would like to find another used, refurbished or ifit is cheap a new Samsung TS-H492A/RSWN so I could easily install since all drivers and programs are already set up.
  • 66 Answers
If the laser stops working then the only solution is replacment or repair oderwise there is no remedy available!!
Posted on Jan 26, 2008
    Genius:
  • 2,985 Answers
There are no remedies for a failer laser except to replace the device.
6ya staff
SOURCE:
My drive can not read dvd
Yes lasers that read dvds work on a slightly different frequency so as laser wears over time, especially when burning instead of just reading it effects the ability to read and or write to DVD media and it is why reading and even writing to cds can still be done but not so with dvds. Might be time to replace it.
Apr 20, 2013 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
I have problem with my AVERATEC COmputer
This is a common issue with NEC DVD burners, assuming that your NEC DVD burner cannot read and write DVDs anymore. I had a similar issue with my NEC DVD burner, which couldn't read and write CDs, but DVDs successfully. This is usually due to wear and tear of constant usage of the drive itself and sometimes mechanisms inside the DVD burner cease to work. While Windows Troubleshooting, uninstalling and re-installing the drive are suggestable, I am afraid the only option is a complete DVD burner replacement.
Feb 22, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Sony DVD RW DRU-710A won't burn dvds
sounds exactly like my old dead drive. if it cant boot from a cd its likely a bad drive
Nov 02, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Sony DRU 700A, can't play/write DVD
go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive Good luck!
Oct 28, 2006 | Sony Dual layer (DRU700A) DVD±RW Dual...
Samsung TS-H492A/RSWN CD-RW/DVD-ROM (Combo) Burner Logo
114 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
