Question about Marantz CD-48 CD Player
Sound only coming through one channel
If I connect my CD48 to my amp and speakers, using standard audio cables, I only get sound from one speaker. If I remove the red connecter, leaving the white in place, no difference. Removed the red connector only and nothing. I have checked other components through the amp, and no probs.
    New Friend:
  • 120 Answers
Check the white connector jack.
Posted on Jan 26, 2008
  • 1,512 Answers
Try swapping the t5he red connector to the other channel. if the fault goes to the other channel then the rca lead may be faulty. if the fault appears to be a dead channel in the player , you may have to do some resoldering about the rca connector on the back panel. They sometimes can develope dry solder joints. Worst case you may have a D/A convertor problem. I have not seen many faults in audio stages beyond the D/A (TDA1549) in the player. If you are not confident with electronic repair work I suggest a marantz agent to repair it. I have been for 20 years, but am in Australia. Good luck, happy to give you more advice if you need it.
  • 36 Answers
You may possibly have a fault with the RED RCA output plug on your CD possibly a loose wire on the internal side or a faulty plug altogether. Try plugging it into another stereo and see if the problem replicates itself.... if so then i am sure that will be the case.
No sound out of left channel pioneer vsx1123k
Make sure that you have analogue stereo sources (red & white phono/RCA) connected to any input that you want to have routed to Zone 2.
Check your speaker connections for Zone 2: Correct sockets, and make sure the wires are connected properly and there's no little strands bridging between the black and red terminals on the amp or at the speaker ends.
That's about it.
If there's no sound on one channel then it's most likely to be either a bad speaker/speaker cable connection, or a broken source cable. Try the FM/AM radio (hook up an aerial temporary). That'll be guaranteed to be either stereo or at least dual mono so both channels should work.
Jul 12, 2014 | Audio Players & Recorders
2010 VW CC factory stereo amp popping sound
If the amplifier itself is making the popping sound I suggest you disconnect it immediately, as it could be an electrical short within the amp. If the popping sound is actually coming from the speakers, it could be due to a crossed wire, blown amp channel, or blown speaker. If you posses the technical know-how, you can test the amp channel and speaker by connecting a different speaker to the channel responsible for the popping sound. If the new speaker makes the same popping noise then it is most likely a blown channel. I hope this helps =)
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
My Sanyo DP23845 23 In. LCD Television does not have any options under set up beside color-how do I add channels?
HDTV inherently provides a superior sound quality simply because the sound of HDTV is digitally transmitted. The difference in sound between an HDTV television and an analog television is rather noticeable. In fact, it is directly analogous to the difference between the music on CD's compared to the music on audiocassette tapes.
The difference in sound quality provided by HDTV televisions and programming does not end there. Many HDTV programs are also broadcast in Dolby Digital 5.1 surround sound, but in order to take full advantage of this technology, it is necessary to have the right equipment.
Dolby technology has been created by Dolby Laboratories, Inc. This technology is the most renowned provider of digital audio technology. Also, Dolby Laboratories is known for reliable and superior products. For these reasons, Dolby Digital Surround has become the standard for HDTV. Many television manufacturers substitute their own surround sound systems, but they cannot live up to the reputation and performance of Dolby. Therefore, it important to check the specs on an HDTV television before buying in order to ensure that it uses Dolby Digital Surround.
When using Dolby Digital Surround Sound, there are three options for set up. The first option is to buy a television with high quality center channel speakers, woofers, tweeters, and Dolby technology installed in the television. With this option, it is unnecessary to buy addition equipment to take advantage of Dolby Digital Surround Sound.
Another option for taking advantage of the Dolby Digital Surround Sound with an HDTV is to connect an external set of surround speakers to the television. With this option, the surround sound set up includes a front pair of speakers, a surround pair of speakers, a center channel, and a subwoofer. Sometimes, the front speakers are "powered towers." This means these towers include subwoofers.
The placement of these speakers is very important for the quality of the surround sound. The Center Channel Speaker should be centered either above or below the television. The Front Left and Right Speakers should be placed in an arc formation in line with the Center Channel Speaker. The Surround Left and Right Speakers, on the other hand, should be placed to the left and right sides behind the listening position. Many people choose to wall mount these speakers.
The third option for taking advantage of the Dolby Digital Surround System included in an HDTV television is to use an external set of front speakers can be connected to the HDTV television. This configuration is useful if there is not enough room to set up the external surround sound system and the HDTV does not come with Dolby Digital Surround installed. This isn't true surround sound, but it is a viable alternative to those who can't take advantage of the first two formats.
The audio and video outputs of the DVD or VCR can be connected to the AV receiver's video outputs. If a separate DVD and VCR need to be connected, one can be connected to the VCR1 connection and the other can be connected to the VCR2 connection. The AV receiver's VCR video and audio outputs should then be connected to the audio and video inputs of the DVD and/or VCR. In this way, the DVD and/or VCR will be able to record video signals that come through the AV receiver and the VHS tapes and/or DVD's will be able to be viewed on the HDTV.
To take full advantage of the Dolby Digital Surround Sound technology, one of the video outputs of the DVD player and/or VCR needs to be connected to the AV receiver. The digital coaxial audio or digital optical connection must also be connected to the AV receiver.
How do I connect my CD player?
A CD player can be connected to an AV receiver. The CD player's digital audio outputs can be used to connect the CD player to the AV receiver. A CD-Recorder can also be connected the AV receiver by using the Audio Tape Record/Playback input/output loop connections. In this way, the CD-Recorder will be able to function much like a standard audiocassette deck.
What else will I need?
Besides the basic electronic equipment needed to set up Dolby Digital Surround Sound, it is necessary to have connection cables. This includes video, audio, and loudspeaker connection cables. These cables need to be at an appropriate length in order to set the speakers in the proper position for optimal surround sound quality.
Jul 29, 2012 | Sanyo DP23845 23 in. LCD Television
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Only 2ch sound on sony strde898
I understand that you have tried connecting different audio source to the Receiver as some of the audio source will output only 2 channel audio. I hope you have tried changing the Input mode and Input selector to get the surround sound.
Please disconnect the speakers with the receiver and clean the edges of receiver and speaker cables using solution like alcohol and try.
If the issue persists, please interchange the rear speakers with front speakers and vice versa and check if audio is coming to make sure that the speakers are working fine.
If the audio comes after replacing the speakers but not from surround speakers, the receiver requires service.
Sep 22, 2009 | Sony STR-DE898 Receiver
Left channel will not play
Firstly try swopping over the left speaker to the right channel . If still no sound then either the speaker cable will have a break in it & need replaced or the actual speaker will be open circuit. If you get sound from the speaker on this channel then the the speaker is ok. Check your PC's audio set up... Go to Control Panel/ Sounds & Audio devices/ In volume Tab, click in Device volume area... Advanced & then check the Balance settings are not set to one end.
Jul 22, 2009 | Dell A525 Computer Speakers
Have a 5.1 sound system, one audio cable connected to the green port one to the black but only the bass and speakers connected to the green port work. switched cables around; speakers and cables ok. PS...
Sounds like you just need to enable all the channels in your sound control panel. In Vista this can be done by right click on the speaker icon and going to the properties of your sound card. If you have software installed specific to your sound card go into that software and there will definitely be a setting / question regarding how many speakers you are using. By default it will only use the green channel.
Jun 25, 2009 | Creative Labs Sound Blaster Audigy 2 Value...
Left speaker gives no sound
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Jun 07, 2009 | MSI PM8M2-V Motherboard
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Sep 22, 2006 | Yamaha RX-V550 Receiver
150 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
