Question about SanDisk Sansa e250 MP3 Player
It´s dead hi, some days ago i bought a new sansa and have been using it. It came already with a little of charge but i charged it up completely. this morning turned it on (it didnt have much charge) and fell asleep. when i woke up it was off and culdnt turn it on. i thought to charge it, but when i connected it to the power outlet nothing happened. not even with the pc connection. its like dead. thanks for your help!
  • erkni Jan 25, 2008
    it worked thanks a lot ;)
    Problem Solver:
  • 9 Answers
Hey buddy just do one thing.. open the metal cover removing the 4 philips screws.. and then remove the battery then reinsert the battery and try.. it should work ... i had the same thing few days back.. it was charged and in my pocket when i tried to listen to it the damm thing wont switch on .. so i removed the batter and put a LED to the terminal to check power and inserted it back it and valaaa it hot and running again..
Posted on Jan 25, 2008
SOURCE:
My Acer Aspire one dosent charge completely to 100%, it stops at 87%. I have tried letting the battery run down completely, then starting a new charging process. formally it charges to 100%, then 3 days...
Hello.
From your description, your battery is losing its charge and needs to be replaced.
I'm experiencing charging problems with my own system and I noticed that the A/C adapter is very slightly frayed. So, check your A/C adapter as well and be certain that it is charging when you leave your system charging overnight. If you are still experiencing a problem, replace your battery.
Hope this helps.
Apr 02, 2011 | Acer Aspire One PC Notebook
My Sansa Clip MP3 Player is almost new, however the battery only last about 3-4 hours from fully charged. But now it appears to be completly dead which my computer will not even recognize it to start the...
Hey, greatings from lithuania
i have the same problem. Couple days ago i changed the battery from another sansa clip ant it worked fine, pc recognized sansa again :/ i think that the battery is dead , detailier the microchip wich is on the battery..
Oct 26, 2010 | SanDisk Sansa Clip MP3 Player
Phone sometimes takes forever to charge. I have it plugged in at night and it is still charging the next morning with no to little progress. Sometimes if I shut down the phone and restart it, it charges...
hey bro
your problem is in the hardware, the CHARGE IC problematik. you need to go somewhere close to you so some one will change it for you. and than all will be OK.
memeh Fixphone
Mar 31, 2010 | Motorola Mobility V195 Cellular Phone
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa clip mp3 1GB problems
the best way to solve the problem is to return it to the store! let the sudisk solve the problem and only after that to sale them
Mar 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250
alright just take the battery out and put it back in and turn on ur mp3 player.
it takes a little power to take the battery cover off though so dont fell stupid if ur using all ur energy.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Sansa c240 battery issue
Does it indicate that it is fully charged? If it does, I would return it or have it replaced. You have a 1 year warranty from SanDisk. SanDisk Technical Support 1-866-726-3475 If not, try using a different USB port on the computer, preferably one in the back. Best of Luck.
Sep 14, 2007 | Audio Players & Recorders
SanDisk Sansa e250 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
