Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 I have an error when I try to print. Says Cartridge Stall. I tried everything. Looked inside and there is a spring sitting there on the base of the printer. Is there a manual to show me the inside so I can put it back where it belongs?
  • Poohie Jan 27, 2008
    Thanks for your help, however, the 1160 isnt the same inside as the 1270. I WISH IT WAS. I actually got it apart and everything. Thought I found where it went, but when I tried to print it didnt work. Any other pictures? Maybe of the 1270?? THANKS FOR YOUR HELP!
  • 21 Answers
This spring is behind the cartridge dock. If you look carefully the placky part holding the hole caboodles is snapped but it don't worry me as it's out of service now anyways, it's also a X1160 but the gut's are more than likely the same if that's not the spring in question there are a few other springs but not likely to effect the print error?
hold on let's just take a few more snaps and put them under the most likely one...
on second thoughts ignore all that it maybe the one attach
this spring isn't attached but you should see where it hooks up to, on the left of the highlighted part of the pic. ( the printer has been dismantled so it's not shown with all the exact parts but you should be able to distinguish from what is shown hopefully)
this one is in the middle of the machine to the left of the PCB (yes or nay)
Posted on Jan 26, 2008
  • ben dobson
    ben dobson Jan 27, 2008
    Lexmark couldn't have changed much inside ? what's the spring look like ,small wide short, have you got a pic, of it (scan it if no camera)
    your call!
    Genius:
  • 2,985 Answers
You could try www.fixyourownprinter.com
Type in the field your printer make model and go to Forums
6ya staff
SOURCE:
Lexmark all-in-one has error message for cartridge stall.
there maybe stuck little paper or something inside the device or maybe the cartidge is broken or the holder of the cartidge i think an expert should see it .. it must be seen and heared to solve it and try to clean it from inside
May 17, 2014 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1270. The paper goes to right and can not feed to print.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area.
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X1270 All-In-One InkJet Printer
I just purchased a new black ink cartridge for my printer and it is not printer. The printer stop printing. I have a Lexmark X1270
Try to re-seat your cartridges into the printer.
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. Close the printer cover.
  4. Unplug and re-plug the printer into the power source to reset it.
  5. When the printer turns on, re-insert your color cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, open the printer cover and reinsert the black cartridge. Close the cover and check for errors.
  7. If error appears when black is inserted, try to insert a different known working cartridge (your old cartridge maybe) to determine if it's a faulty cartridge issue.
If you can make a copy using the Copy button on the printer operator panel without a problem, then it could be a communication problem between your printer and the computer. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply reboot your pc and unplug and re-plug the printer into the power source to reset it. When everything is back on, try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Its a lexmark x1270 scanner n printer. it would not print since the new cartridge has been put in it says that the cover is open though its not and the support info i got i did everything the manual said...
It could either be the cartridges in the carrier or the sensor for the printer cover has gotten stuck. Please follow the steps below to determine and fix the issue:
  2. Remove the cartridges from the carrier.
  3. Close the cover.
  5. When the printer turns on, re-insert one cartridge first. Close the cover.
  6. Check for any error.
  7. If none, re-insert the other cartridge. Close the cover.
  8. Check for any error.
  9. Replace whichever cartridge is causing the error to appear.
  10. If no error, try to print again.
Jun 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Red colour not printing
try to clean the pinout of the cartridge with Acetone also try to clean the Pinout of the cartridge mount inside the printer
Jun 08, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X1270 All-In-One InkJet Printer
Help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 Loose Spring
well poophie do one thing call up the cutomer care , re check when u had bought the printer is the stll the printer is in warranty , try to get a replacement for it
Jan 25, 2008 | Lexmark X1270 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
314 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
