Data recovery when i start my PC it boot for a sec. and then restart. my important data is on it. how can i save my data ?
    Novelist:
  • 171 Answers
Remove the hard drive. Put it into a working computer as a slave drive. You can then access the hard drive from the second working computer to save your data.
Alternatively, buy a 3.5" hard drive enclosure (like this one: http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&MSCSProfile=3C79F0C7EA3162B2D7ADAC57314A0E6A590377F958863102EDBCF732E27F5F9388E0A55795B25749B2DCA82F3E403B752755F32E5B789E64D63C62D3278A64336587C84A5489154B0DA4873945D091EB3A885032FFFAB317F456B0258935E9F951596CC147AFD5FE7493D1CB0BD503269C7C090911A34F48&sku_id=0665000FS10092821&catid=11288 ) and put it in there, then you can plug that into another working computer via usb and access your files that way.
Third alternative, boot to a rescue diagnostic disc such as the Ultimate Boot CD http://www.ultimatebootcd.com/ and you can access your hard drive from there. This is an option for advanced users, since a lot of the diagnostic tools are command prompt driven and require you to understand a little about the insides of the computer. You will need another external hard drive or usb key or something to copy your data to.
Posted on Jan 25, 2008
Factory reset
Do not rename the backup folder created by Samsung Recovery Solution or change the directory structure in the backup. If the name or structure has changed SRS will not see your recovery point when you attempt to perform a restore.
This restores the PC to the condition it was in when the Complete Backup was made. If a Complete Backup was never made, this can still be used to restore the PC to its initial status. (Out of the Box condition)
Warning: A Complete restore erases all current files, settings, programs and other data and replaces them with the files, settings, programs and other data contained in the Complete Backup. In other words, it restores your computer to the way it was when you made the Complete Backup. Also, note that any programs installed after the Complete Backup will still need to be reinstalled.
Important:
  • If you have data that you need to save, create a Data Backup before performing a Complete Restore. With Data Backup you can save your files to an external device and then use Data Restore to load those files back onto the PC.
  • If the computer powers on, but Windows does not load, press the F4 Key at the Samsung logo when you first power on the computer; and then go to step 2.
  • If the Samsung Recovery partition has been removed from your PC, your notebook will need to be sent to the service center for reimaging.
To perform a Complete Restore, follow these steps:
  1. Open Samsung Recovery Solution 5.
  1. Once Samsung Recovery Solution 5 loads, click Restore. The Restore dialog appears.
  2. Click Complete Restore. The Restore > Complete Restore dialog appears.
  1. On the Restore > Complete Restore dialog, there is list of backups created using Complete Backup and the expected time needed to perform a restore with each backup. If no backups have been created then the Computer Initial Status backup is the only item listed. Click the backup you would like to use for this restore, and then click Next.
  2. Important: Make sure you have power connected to the PC. If power is lost during a restore, you need to start the process again from the beginning.
  1. Samsung Recovery Solution 5 prompts you to restart the computer to continue. Click OK to restart the computer.
  2. Warning: If you have data on drive C that you do not want to lose, stop now and perform a Data Backup.
  1. The computer restarts and Samsung Recovery Solution 5 prompts you to click Yes to Delete all data on drive C. Click yes to proceed.
  2. A progress bar appears showing the current transfer speed, the amount of data copied, elapsed time and estimated total time to completion.
  3. After the Complete Restore is complete, Samsung Recovery Solution 5 prompts you to restart your computer. Click OK to restart.
  4. After you restart your computer, the restore process is complete.
  5. Note: You will need to perform an additional restart for Windows to apply its changes.
Nov 22, 2013 | Samsung R519-53S Notebook
When i try the acer system recovery it keeps coming up with an error that says windows could not install and setup with resume when computer restarts..restarts ands same box pops up? cannot get past that...
Have you tried booting to the system recovery again and starting it over? Otherwise you may need to wipe it clean and start from scratch. Download a program like Darik's boot an dnuke to wipe the hard drive clean (this will destroy all data on the hard drive, including system recovery data if that is saved on the hard drive instead of CD's.) Then try the system recovery again (if it's on CD's)
Jun 24, 2011 | Acer Aspire One PC Notebook
While am installing the recovery disks I had this problem error fa12-045d and i had it in disk number 3 ?????
first put disk in then restart computer when prompt push f2 ok now go boot format witn arrows on key board change boot format f12 its already set f2 but its better this way your disc will push f10 save formate start right away now restart push f12 now go under sec. option.
Feb 05, 2011 | Computers & Internet
I had to do a recovery last night everything was going fine until it started loading the system settings then the system just restarts itself and then comes up with an error saying that an unexpected error...
Restore to factory settings:
If you want to restore your computer to its original settings without
recovery CDs.
Note: If your system is the multilingual version, the operating
system and language you choose when you first turn on the
system will be the only option for future recovery operations.
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press <F2> during POST.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 15 GB in a hidden partition on
your hard disk
Jan 10, 2011 | Acer Aspire X3400 PC Desktop
Missing !!0xc01a001d!! 28704/98270 (\Registry\Machine\Components\DerivedData...) I can't boot up, need help how to deal with this issue please!
To restore computer to its original settings without
recovery CDs.
Note: To activate the BIOS utility, press <F2> during POST..
your hard disk
Jan 09, 2011 | Acer Aspire 5315 Notebook
My sony vaio VGN-CS22GH laptop shuts doen by itself randomly. Please help
The issue may be due to any recent hardwrae or software changes and also due to any virus.
1. Remove any recently added hardware/software.
2. Try to boot the computer in safe mode. Press F8 button soon after restarting the computer to enter the advance boot option and select safe mode to boot computer in safe mode.
3. If issue persists even in safe mode, perform a system restore to an earlier time or date when the computer was working as expected. Performing system restore will not delete any data from the computer.
4. Reset BIOS to default values. (Press the F2 key after restarting the computer to enter and access BIOS).
5. Press F3 and F4 keys to reset the BIOS. or press the right arrow key until you reach the exit menu, then select the load BIOS default option.
6. Then, select the Yes option when promted, save the settings and select yes option. restart computer and check.
7. If still persists, perform a system recovery using the VAIO Care Software or the F10 recovery partition.
Note: ensure to backup any important data before perfoming system recovery. System recovery will erase all the data presnt in the computer.
Nov 07, 2010 | Sony VAIO Notebook
Hi guys got a problem my compaq presario going to boot menu when i try to start windows normaly or safe mode or recovery date it just restarts & goes back to the reboot page please help.
Sounds like a hard drive problem. Try and boot from a windows instalation cd and select repair windows. If this do not work and you have very important info on your hard drive i would take it to be serviced and data saved. If it is not important data on the hard drive reinstall a fresh copy of windows.Good Luck
Nov 24, 2009 | Compaq Presario Sempron 2.0GHz Desktop...
I cant get my gateway mt3705 to format,only three options setup available for boot menu,boot seq,setup and psx boot menu..no recovery disc either what do i do?
To delete everything on your hard drive and re-install all factory software: 1 If you can still run Windows: a Click Start, All Programs, Gateway Recovery Center, then click Gateway Recovery Center. The Gateway Recovery Center opens. b Click Recovery, then click Next. Your computer restarts. - OR - 2 If you cannot run Windows: a Turn on or restart your computer. b While the computer is starting up, repeatedly press F8 until the Recovery Options screen opens. If Windows starts to load instead, restart the computer and try again. 3 Press the arrow keys on your keyboard to select Repair Your Computer, then press ENTER. Gateway System Recovery starts, and the System Recovery Options dialog box opens. 4 Select a language and keyboard layout, then click Next. 5 Click the User name box to select a Windows user account, click in the Password box and type the user account’s password (if any), then click Next. The System Recovery Options menu opens. 6 Click Restore Application. The Welcome to Gateway System Recovery window opens. 7 Click Next. 8 To perform a recovery with data backup (recommended), click Recovery with automatic data backup, then click Next. Important Before your hard drive is recovered, your personal files will be automatically backed up to c:\backup. - OR - To perform a full factory recovery without data backup, click Full factory recovery, then click Next. Caution Continuing with the full factory recovery will delete everything on your hard drive. Make sure that you have backed up any important files you want to save. 9 Click Yes, then click Next. The Factory image recovery window opens, which shows you the progress of the system recovery. When recovery is finished, the Recovery is complete window opens. 10 Click Finish, then click Restart. Your computer restarts in its original factory condition. You still need to reinstall any software that was not pre-installed on your computer. If you selected Recovery with automatic data backup in Step 8, you can find your backed up files in c:\backup.
Sep 01, 2009 | Gateway MT3705 Notebook
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
I want to restore my laptop to factory settings. I have a compaq, presario v4000 but it did not come with a system restore cd.
baby,
There is an option to make system restore disk for your Lap.
Goto Start->Program -> HP Recovery -> Create System recovery.
WARRNING: its one time runnign software. So use good quality DVD to make your recovery DVD and keep it safe.
It might take 2-3 DVD so be patient as it will take time.
  • After creating DVD, make copy of all your important documents/file to any where like flash memory/CD or DVD as all the files and softwares will be deleted which you have installed/copied or saved after first boot.
  • Then re-start your lap with the created first recovery DVD.
  • Follow the on screen instructions...
There is also a way to run your recovery from your HDD.
  • Keep pressing F9 after booting your lap till Boot Selection menu appears. Select Recovery and follow the on screen instructions. But before recovery make all backups of your important data.
If any question just..Ask me.
Thanks
Iqbal
Apr 26, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Alun Cox
David Payne
David Payne
