No plug for my kenwood car cd player got one now but i need to insert the red live and the ground myself dont have a clue an i dont want to blow the set the model kdc.8090r
  • 36 Answers
To find the positive wire for your stereo you should really be using a multi meter. you can pick up one relatively cheap at any Hobby Electronics store. If you are still unsure then I really think you should get someone who has installed a car audio system before to help you.
Posted on Jan 25, 2008
Hooking up kenwood cd player in a 2000 silverado but the wires aren't labeled coming out of the cd player. Pls help
If you use a wire harness adapter, you just have to match the colors from the Kenwood plug to the wires in the adapter. No guesswork.
Kenwood uses the CEA standard for car audio wiring:
Yellow: 12VDC constant power
Red: 12VDC key-switched power
Black: Ground
Orange/White: Illumination
Blue/White: Remote output for amp turn-on
Blue: Power antenna activation
White: Left front speaker (+)
Gray: Right front speaker (+)
Green: Left rear speaker (+)
Violet: Right rear speaker (+)
Each wire with a black stripe is a negative speaker output.
You can download owners' manuals from Kenwood's web site.
http://manual.kenwood.com/en_contents/search
Jul 16, 2015 | Kenwood Car Audio & Video
Kenwood single cd player dp-2030. I insert cd, it reads fine responds but I get no sound.In the back of unit speakers are plugged into line output.
Speakers don't generally run off Line Out. What kind of speakers? You probably need an amp for the speakers. Unlike wiring is usually a clue to incompatibility.
Mar 03, 2011 | Kenwood Audio Players & Recorders
My Kenwood DPX-4020 suddenly went "dead". No power whatsoever on the led's and nothing happens when i push any/all of the buttons. I have it reset many times, checked the wiring's and fuses at...
1st you need to check the fuse in the fuse panel in your car to see for some reason the radio fuse is not blown . if is change it . if not take your radio out and see if fuses for radio is blow on back of radio then some have a fuse on the red wire check fuse there too. if nothing buy a digital volt meter and start checking your ground wire to see if it broke . take volt meter turn on dc volts put black test lead on your radio ground then take the red test lead and and start touching the yellow wire to see if you get a 12 volts on meter if you get 12 volts ground is good ... then check the red wire turn on the ignition switch and put the red test lead on red wire and see if you get 12volts if nothing
either you have bad ground or you have a fuse blow in car some were .. if you can't figure it out call a local mecp certified shop and have them look at it ....
its possible that the radio is just died and you need to buy a new one electronics dont last forever when you use them daily ...
http://www.tintingbyfredjohnson.com
Dec 27, 2010 | Kenwood DPX-4020 CD / Cassette Player
How do i install a kenwood kdc-135 to a '96 mazda truck and i dont have a red and yellow wires or the ground
the wire colors in your mazda will not match the colors on the kenwood stereo. you need a test light to find the right wires
Feb 07, 2010 | Kenwood KDC-135 CD Player
Tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Mar 04, 2009 | Pioneer DEH-P6400 CD Player
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
How to wire a kenwood kdc d300
All components on your Amplifier should be labled. Ground Will go to any ground on your Vehicle Ex. A bolt under your trunk floor cover. Power has to be ran from your positive terminal onto your batter and throught the interior of your car to your amps 12v +. The MEMORY TERMINAL IS NEEDED FOR FUNCION! It will be between Ground and POWER or NEXT TO POWER.. This has to be ran to your cd players BLUE MEMORY wire or you can bypass it directly to the POWER, WARNING!!! if you use the bypass method, put a switch that you can pick up from any autozone or such between the two points to shut off the amp, other wise it will run constatly and kill your battery. The two RCA's have to be plugged into the back of your cd player and ran back to your amp and plugged into the Primary Slot (red-white) and finnaly the +.- speaker wires need to be ran to your subwoofers. Once all conected pop in a cd, adjust your cd players bass settings and also adjust your lows, mids, and highs on the amp to fine tune your speakers. IF you are looking to maximize your speaker wattage, you can use the bridge teqnuiqe. But beware you are going to doubble the ammount of power into each speaker. Take both positives, or if only one speaker just the single possitive, and place it into the Right SPEAKER insert on the Amp, and take both negitives and place it into the LEFT SPEAKER insert, and run the wires like normal to each speaker, 1 wire per - one wire per positive, in doing so both speakers run using maximized power usage
Sep 11, 2008 | Kenwood Car Audio & Video
When i turn my headlights on my stereo turns off
you problably hookied the Illumnation lead to the ground lead on the radio, it will appear as a ground with the lites off and go live 12v @ lights on.
Reground it :)
Jul 03, 2008 | Kenwood KDC-135 CD Player
Hooking up a Pac Ipod Cable
the pac cable plugs in to the back of the stereo you cant get it wrong its a big round plug and the place you plug it in at is right next to the red and white rca plugs at the bottom of the big chunk of alluminum now if you need any more like getting the player out of the dash post a new comment listing the type of vehicle and instalation ex..dash install kit usualy scouch
Jul 19, 2007 | Alpine CDA-9827 CD Player
35 people viewed this question
 Grubhead
Grubhead
