Question about Ovens
Remove Outer Glass Of Oven Door
How do I remove the outer glass of the oven door to fit a replacement
  • st2malo Jan 25, 2008
    Matsui MSP60SS Oven/Hob
  • Anonymous Apr 15, 2008
    remove front door class from oven
    Problem Solver:
  • 4 Answers
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Posted on Jan 16, 2010
    Scholar:
  • 196 Answers
Depending on the unit there should be several screws on the top and bottom of the door. Thesse screws hold the door sections together. Once the screws are removed the inner glass section should slide out (you may have to remove the bracket screws.) From here there should be some small clips that hold the front glass in place.
Posted on Jan 26, 2008
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Removal and disassembly of oven door
The panels on the door , specially the glass panels can be removed easily if care is taken to remove the fitting screws.
You can use a good cleaner glass cleaner to remove any dirt that has deposited on the frame and glass panels.
Once the glass is dry it can be refitted , care taken to use gloves so as to avoid hand impressions .
Dec 06, 2011 | Fisher and Paykel Ovens
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
1,614 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
