Question about Samsung YP-U2X Digital Media Player
MTP Connected then dont disconnect then shuts off
Alright it seems that alot of people are or have had problems with this thing, I had given up on it for a while now and was just gonna get a new one but I'm trying to fix it through this place to see if I can get some reults. I tried to install the latest version of firmware and that went ok, now when I connect it to my computer it either says MTP Connected and shuts off or it says MTP connected then dont disconnects and then shuts off, any help would be greatly appreaciated.
Where the hell are the solutions to our fucking problem?
Posted on Feb 10, 2008
Sony Walkman NWZ-E438F connects & disconnects itself from USB
I suggest that you uninstall and reinstall the USB Driver to resolve the issue.
Follow these steps to uninstall the driver and confirm the player is recognized properly.
IMPORTANT:
  • This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  • If you are using the Windows® XP operating system, you must have Service Pack 2 or later installed.
  1. Click Start and then click Control Panel .
  2. In the Control Panel window, click Performance and Maintenance .
  3. In the Performance and Maintenance window, click System .
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, under Device Manager , click the Device Manager button.
  6. In the Device Manager window, click the plus (+) sign in front of Disk drives .
  7. Click to select the Sony USB device .
  8. From the menu, click Action and then click Uninstall .
  9. In the Confirm Device Removal box, click OK .
  10. Disconnect the portable player from the computer.
  11. In the System Settings Change box, click Yes.
After that, restart the computer and reconnect the Player to resolve the issue. USB Drivers are generic to the Operating System and will reinstall automatically after restarting the computer. I hope it works.
Sep 22, 2009 | Sony Walkman NWZ-A826 Digital Media Player
Running problems with a 94 Ford Probe GT
check the fuel pressure, it should be over 40 PSI, also this can be caused by defective Mass Air Flow sensor or MAF for short, has your fuel filter been changed?if not it may be clogged.
Mar 13, 2009 | 1994 Ford Probe
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
MTP Connected but not Accessible
It is simple. Forget the MTP Mode. Simply put the player on, put it on hold, press and hold the record button while you plug in the cord. It will go into USB mode, the only thing is that you have to do that everytime. Hope this works.
Jun 30, 2008 | Samsung Yepp YH-J70 Digital Media Player
Creative zen v plus
i had the same problem but solved it, it seems that the usb driver does not always install with the software installation so you must install using the DEVICE MANAGER make sure first your mp3 player is connected, so ( copy & paste) your software to desktop, then go to CONTROL PANEL, then SYSTEM, then HARDWARE then DEVICE MANAGER, in device manager you should see ( zen v plus ) with a yellow question mark above it, which means the drivers are missing, click onto that and follow instructions to install the drivers which you will find in the software you have pasted to desktop. good luck, tony spain
Mar 22, 2008 | Creative Labs ZEN V Plus MP3 Player
Switch from MTP to USB
I had this same problem and was able to solve it. Just go into Control Panel (make sure it's in Classic View)-> System -> Hardware -> Device Manager, right click the GPX icon under Protable Devices and then click unistall. Then disconnect and reconnect the player. Windows will automatically install the drivers and that's it, you can now go into USB mode again. Hope it helps.
Jan 20, 2008 | GPX MW3837 MP3 Player
Trouble downloading music to my enV
that was the same problem for me. when you download that vcast software dont use there program. use windows media player 9. that has worked best for me. ive tried the latest window media player out and it doesnt seem to work. but if you use 9 you can go to sync with your phone connected. and you always have to make sure that you go to settings and tools on your phone. then go to call settings and then you should see pc connections and when you get to that you should see usb and you click on that and it should say pc connection set. hopefully any of those options i gave you work out.
Jan 13, 2008 | LG enV VX9900 Cellular Phone
MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
Dec 29, 2007 | Samsung YP-K3 MP3 Player
Disconnecting player while in MTP mode
It is not designed to show up as a Removable Disk in MTP mode, therefore it wont show up in the Safely Disconnect Menu.
If you are using Windows Media Player to transfer, as soon as the SYNC is complete, it says "ok to disconnect". You can disconnect without any problems.
If you are using Rhapsody, or the Best Buy Digital Music Store, you can right click on the device in the Sources Menu and select Disconnect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
Problem with drag and drop
(FOUND THIS SOLOUTION ON AFTERDAWN.COM) The problem is that this player have 2 standards for connecting to PC. One is MSC and other is MTP. Each one have different directories structure. If you put music when your player is connected as MSC, when you will conect as MTP you'll be not able to see the files uploaded previous. The same case is available when you write music files as MTP=> you can't see these files in MSC mode. So, set USB mode of your Sansa as MCS, power off, put hold switch to lock and connect to PC. You will see 3 directories: Audible, Records and Config (or something like that). See if your "invisible" music files are here. If they aren't connect as MTP. To connect as MTP: set USB mode to auto, shut down Sansa mp3 player, put hold switch to unlock and connect to PC. You will see only 2 directories now. Media and "something" (I can't remember now). Look for your "invisible" files and do what you want. MTP mode is for use with newer PC's. I advice you to use MCS mode all the time because is compatible with any PC (old or new). Good luck!
Aug 30, 2006 | SanDisk Sansa m230 MP3 Player
Samsung YP-U2X Digital Media Player Logo
56 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
