Question about Cyber Acoustics 3-in-1 Headset/Mic Headset
Cyber acoustic ac 208
When i plug the green and pink jack in i cant hear sound but when i take out the pink jack which is the voice ii can hear sound but when its plugged in i cant hear anything at all
    Problem Solver:
  • 5 Answers
The issue lies in the glass fiber wire, the wire is coated with a conductive metal only a fe mircons thick.
Simply put the headset is a poor production model, the use of glass fiber wire more often than not results in a short in the wiring. Thus the sound will come out of one side, not at all, etc.
Posted on Jun 15, 2009
What about if the headphone doesnt have a usb...instead it has 2 cables, a pink one and a green one?
Those are separate connectors for the earphone (green) and microphone (pink). Plug them in to the appropriate connectors on your computer. On desktops you will find them on the rear panel (maybe also on the front on some systems), and they will probably be color coded the same way. On a laptop, the connectors are usually on the front edge or on one of the sides.
Dec 03, 2010 | Cyber Acoustics AC-840 Headset
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
When i talk people cant hear me though turtle
If you have an X1 headset...
Try using the X1 headset and mic with your PC (sound card). Green plug goes to green jack, Pink plug goes to pink jack. Can you hear your voice thru the X1 mic on your PC? If yes, then the mic works but the chat-controller cable is probably broken and should be replaced. If no, then the mic may be broken and you should contact Turtle Beach's tech support for help -- support@turtlebeach.com.
Mar 04, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
My turtle beach x1 stopped working
What happens if you try your X1 on a PC instead of on your Xbox? That's a good test of the mic... Here's how:
- Plug the X1 USB into a USB port on your PC. - Plug the X1 green plug into the green Line Out jack on your PC. - Plug the X1 pink plug into the pink Microphone jack on your PC.
Try recording the sound of your own voice on the PC, using Sound Recorder or whatever. Do you hear the sound of your voice? If so, your mic is working and the X1 chat/controller cable is probably broken. Replace the chat/controller cable.
If not, then the X1 mic is broken and you should contact Turtle Beach for service at support@turtlebeach.com.
Jan 09, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
Mic wont work, i can hear friends but they cant hear me.
Can you try using the X1 mic on your PC? Green plug to green jack, pink plug to pink jack, USB plug to USB port. Talk into the X1 mic. Can you hear your voice? If yes, then you probably have a bad chat-controller cable. If no, then your X1 mic may not be working. If that's the problem, you should contact Turtle Beach tech support for help. support@turtlebeach.com.
Dec 24, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Computer wont recognize the microphone on the turtle beach x4
Jul 21, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Cyber acoustics ac-201 and it doesn't work!!
Hi itsonlyerin,
This has to be rather general as it's a bit hard to give you specific advise without knowing a bit more about your operating system and sound card.
Try checking the following:
(1) Headphone problem
First, I would try to determine if there is a problem with the microphone itself. Do you have another pair or a different model that you could try? If yes, then give them a go and see if the other ones work. If they do then take your ac201's back to the store and get a replacement. If you haven't got another pair then try them in another computer and see if you get a different result. If they work in a different computer then the phones are OK and we need to look into the computer hardware and software.
(2) Software Setup problem.
Have you made sure that on the recording controls that the microphone volume is turned up?
(3) Sound Card setup problem.
Some sound cards have multipurpose jack that for example can be switched between line input and microphone. Check with the card's documentation and especially check that the jack you are using is set to microphone and that you are plugged into the right one.
(4) Software problem - do you have the right drivers for your sound card loaded?
(5) Faulty Sound Card - try a different one.
Good Luck
Jul 06, 2009 | Cyber Acoustics AC-201 Consumer Headset
Mic broke
Try using your X1 with your computer. Plug the X1 green plug into the green jack on the PC. Plug the X1 pink plug into the pink jack on your PC. Try using the headset to listen to the sound of your voice. Can you hear your voice through the headset? If yes, then the mic is OK but the chat-controller cable needs to be replaced. If not, then you should contact Turtle Beach tech support at support@turtlebeach.com.
May 23, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Cant get sound
the movement to another place was not the cause of lost program. you just have loose contact, try to remove the sound card then clean then reinstall if you have. if you are using the on board soundcard, check your phone jack if you inserted to the correct one. green is the default and pink is the microphone's default
Dec 22, 2007 | Cyber Acoustics CA-3090 Computer Speakers
Cyber Acoustics 3-in-1 Headset/Mic Headset Logo
89 people viewed this question
Top Cyber Acoustics Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Cyber Acoustics Radio Communication Expert? Answer questions, earn points and help others
