No power is-tvhd30 Flat tube tv. After power outage the tv does nothing at all.
  • 168 Answers
Take the rear cover off, and check the main fuse. If blown, then replace it with the same rating fuse. Next item inline would be a surgister that would have blown. I would check the fuse 1st, and then if you have a multi-meter, check for continuity through the surgister.
Posted on Jan 25, 2008
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
Just had a power outage and now my TV will not come back on. Just flashes 3 consecutive flashes then a pause and then 3 more flashes. Tried unplugging and letting it sit, tried power button on remote and...
I hate to tell you that this happened to me last week and mine is 18 months old. after calling toshiba and going through all troubleshooting, nothing worked. they referred me to a service center near me and the repair is $466!!!!! I have lots of power outages so they can seriously damage a tv (the motherboard to be specific). Mine is the 42 inch 535U. get a surge protector for your cable and ask your electric company to install a power shield on the meter or a surge arrester.. good luck.
Nov 08, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
After a power outage yesterday, my 24" Pure Flat Tube Stereo TV (TTM-2420) is not receiving power. (the glowing light on front of TV is not on and the TV cannot be turned on) I don't know how long power...
Surge protectors are meant to trip whenever an outage occurs to prevent component damage. If possible remove back panel and check if any fuses were burned. If all looks normal then your component is most likely fried.
Jul 05, 2009 | Televison & Video
Insignia tv-30 inch ---model is-tvhd30 has burned capacitor-c359--need to know the value in mfd's.
If it is in the power supply better check the rest of them. most should all be the same value so you may be able to get the value for the burnt one from that. good luck
Apr 24, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
Dec 18, 2008 | iLO 2600 Television
IS-TVHD30
I fixed the problem with the "no power on, low clicking noise". The NPN transistor (2SC5931) was shorted. This transistor controls the horizontal hold. The shorting caused the power supply to overload and restart, then recycle. This was the cause of the clicking noise. Unfortunately this transistor was over $50, most likely due to the extinction of CRT's. I did find a replacement transistor 2SC5552, which only cost $2 (but I was able to get it in Mexico). The location of the transistor is located on the left side of the TV (looking from the back). Directly in front of it is the high voltage transformer which powers the CRT (should have a thick red wire). The transistor is attached to a large aluminum heatsink. To remove the transistor you will have to remove the entire electronics assembly to you can easily get to the underside. This was the solution for my TV, but there could be other components damaged.
Apr 14, 2008 | Insignia LCDTV26 26 in. Television
Insignia TVHD30
I, need the exact model no. to see if you can get part for it . need also to know if it uses an external power adapter thanks
Jun 10, 2007 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
