Question about 2wire 1800HG Router (RG1800HG00)
Website in documentation not working
The website listed in the documentation to configure the router is:
However, I get an error page when I try to access it. I do not have trouble connecting to the internet. Any suggestions?
  • ohiotom May 11, 2010
    Try this:
    In the box that opens up type "command" (with no quotes) and click OK.
    A black window will pop up. At the prompt in this window type:
    ipconfig /all
    You'll get a variety of information. Try typing the value of the Default Gateway in the Address bar of Internet Explorer instaed of The address should be something like The numbers may be entirely different, but it will look like this.
    Good luck.
  • 34 Answers
you can find the documents for the same at the below url
With Regards,
Posted on Jan 27, 2008
Hi i want to chang my net password how to chang?
I got the information from the user manual on page 31:
Open a Web browser and access the 2Wire gateway user interface by entering
Click the Home Network tab.
Click the Wireless Settings link to open the Configure the Wireless Network page.
On the Wireless Security section select custom key ,enter new key and then click on Save at the bottom of the page.
By the way the default /current password is underneath the router.
hope this helps
Feb 17, 2012 | 2wire (2701HG-B) Wireless Router
Where and how do i find my access point I'am trying to set up a wireless internet connection
Hi Kregerbc,
If you want to know your Access Point it is the Name of your Network or Network Key (SSID). Usually the Network Name of 2wire router is 2WIRE and the Last 3 digits of the Serial Number of the Router. The Serial Number is located at the side of the router you will find a Sticker and look for the Serail Number you can also see there the Wireless Network Key under the Bar Code. Another Procedure to find the information of the router is to access it. listed below are the steps on how to access the router.
  • Open a Web browser and type or; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your Wireless Connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya.
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
Need to find my wep key for my AT&T 2 wire 2700HG-B DSL router
The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Here you will be able to fine the setting for your wireless connection
Jan 31, 2011 | 2wire (2701HG-B) Wireless Router
I dont know crouter configuration
Look at your computer's IP configuration. Go to Network and Dial-up Connections, RIGHT CLICK on your network and pick PROPERTIES. Click on the Internet TCP/IP protocol, then click on the PROPERTIES button. Make sure that your settings are OBTAIN IP ADDRESS AUTOMATICALLY.
Then get into your status screen and look at the GATEWAY address. Is that ?
(If you are using Windows 95/98/ME, then go to RUN and go to WINIPCFG)
You can also use the COMMAND PROMPT and type IPCONFIG and it will show the Gateway address. If the Gateway address is slightly different, then try to get into it at that address.
Also from the COMMAND PROMPT, (or MS-DOS window) you can use the PING command. Just type PING If your router responds, you might be OK.
Look at the lights on your ethernet card. Is it GREEN, or does it show YELLOW.
Try rebooting your computer and using PING again.
Then the problem presist it's possible that this Router is NO GOOD.
Hope this Helped!
Aug 27, 2009 | Computers & Internet
1800HG DSL modem/router: Cannot access any of the setup pages.
you have to set the unit to default hold the reset button for about 30 seconds the small hole
Jul 11, 2009 | 2wire 1800HG Router (RG1800HG00)
2 wire 2700HG-B Gateway router
Open a browser while you are hardwired (ethernet cable from modem to computer) and enter this address:
It'll take you to admin pages to configure how you want. Be careful though - 2wire can be uber-confusing. Download various instructions of things you want to do BEFORE you start making connection changes.
Mar 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to
Apr 11, 2008 | 2wire (1000-400108-001) Router
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is Try this instead of to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Slo connection to some sites
Log into the router's management console page at page at
On the left side under "Advanced", click on "Configure Services"
Set the "Force Upstream MTU" value to 1396 then hit Submit. Reboot the modem/router.
Nov 28, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 1800HG Router (RG1800HG00) Logo
49 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
