Question about ASUS P5P800S Motherboard
Wiring diagram? hi,ive got a asus p5p800s,im wondering is there a diagram that shows exactly how and where they go,i can see where they go,but theres two ways they can fit,parallel with the pins or across,im hoping you can help,thank you
  • 1 more comment
  • yoyohorse Jan 25, 2008
    hi,i stated in my question it was for the power on switch and the reset button,,led lights,thank you,my mother board is a asus P5P800S
  • yoyohorse Jan 28, 2008
    hi guys,thanks heaps for your help,your answers helped,got the pc up and running,thanks again to all that replied to my question,im sure ill have plenty more,yoyohorse
  • Emelio Navaja
    Emelio Navaja May 11, 2010
    In what particular pin do you intent to connect? can you show me the picture?
    Genius:
  • 1,226 Answers
I assume your problem is solve by kloykie
and castatroy
have a nice day.
Posted on Jan 27, 2008
    Scholar:
  • 119 Answers
From my extensive experience trial and error can sometimes be the best solution here, never had any shorts with this solutution. plug the power supply onto the mboard then with a screw driver touch together two pins at a time on themboard following a the pins on the panel horizontally, when you touch together the right two pins your mboard will power-up then insert the on-off plug on those two pins 99.9% of the time they are plugged facing inwards (the writing on the plug faces towards the major part of the mboard) after that you can insert the led plugs by the same consept of trial and error. You must plug your harddriver to your board to find the hdd led because then it will flicker when found the power led will remain on constantly. with the resert button the 99.9% of the time the pins are directly below, above or adjacent to the power-on pins. when it comes to the usb pins check- . . . . .
they are in this order above if the spare pin is on the right. starting from left to right, starting with the top row insert - red - white - green - black. the same works for the bottom row.
regards
Casta T.
Posted on Jan 25, 2008
    Problem Solver:
  • 17 Answers
Well, there is a name beside the pins where you will put the buttons then if you can see those just properly put the buttons in the pins.. it have to be in the proper pins and as to the what the position is.. there will be a line or a mark where should the buttons be pinned...
btw.... i would like to give you some hint: if the pins goes like this
::::::::::::: = the buttons are usually place horizontally and if this is the position...
:: the buttons are usually vertical.. i hope this can help
Ram used for asus P5P800S
2 x 184-pin DIMM sockets support max. 2GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory.
Or if you prefer it a bit plainer a maximum of 2 x 1GB DDR400/DDR333/DDR266 SDRAM memory.
you will find the full specs as well as the drivers on the asus global website.
Mar 18, 2010 | ASUS P5P800S (90MBL0Q0G0UAYZ) Motherboard
Asus mother board sound driver
Go to the Asus website, www.asus.com. Click on the support link. Lookup your specific board model # and select the operating system you are running. A list of all available files will appear. Scroll down until you find the sound driver. Click on it and download and install. Follow the onscreen instructions and you should be all set. Hope this helps.
Sep 19, 2009 | ASUS P5P800S Motherboard
Need wiring diagram as i had to recase
You can dload that manual in pdf format at the MSI website here:
http://global.msi.com.tw/index.php?func=downloadfile&dno=3536&type=manual
Pages1-4 and 1-5 are the pages you are looking for.
Hope this helps and thanks.
Please rate
Sean
Mar 30, 2009 | MSI MS-6378 Motherboard
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
Microphone
In the back of the computer where all the computer wires are , there is a pink circular jack , you can plug your microphone into that......
Sep 30, 2008 | ASUS P5P800S Motherboard
Asus p5p800s
It could be that you have a damaged power supply which took out your motherboard. When turning it on, what beeps did it make?
Sep 17, 2008 | ASUS P5P800S Motherboard
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
ASUS P5P800S Motherboard Logo
118 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
