Question about Whirlpool LER5636P Electric Dryer
Brand new electric dryer suddenly does not dry well
I have been using my new Whirlpool electric Dryer for only 2 months. All of a sudden it does not dry my clothes well. Clothes are very damp even after over an hour in the machine. There is no lint buildup that I can see and no kinks in the venting going from the machine into the wall. There seems to be good air flow out of the bottom vent on the machine, and the machine does produce heat. I don't know if this is related, but the lint trap on the top of the dryer seems to be catching lint only on the lower edge, not along its entire length.
  • gmvalentine Jan 29, 2008
    It turned out not to be a dryer problem, but a problem with the mesh cover that the builder had put on the end of the roof vent. The mesh was too fine and caught so much lint that it got clogged. We removed the lint and replaced the fine mesh with wider mesh. VOILA! Problem solved.
My dryer does the same thing.
sounds like your dryer's exhaust needs to be cleaned as it is full of lint - the part that connects from the dryer to the wall and also inside of the wall. For Inside of the wall I usually take a fish tape .
also.... i would look at returning the dryer if it is not trapping the lint. i would return mine but it's out of warranty...
Posted on Jan 27, 2008
    Master:
  • 619 Answers
Hi , still on warranty if you let any body the machine the warranty will invalid , you may call technician where you bought that machine .
Posted on Jan 25, 2008
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
My new whirlpool dryer model WED5300VW0 Ser MO3398130 does not dry properly. It takes 2 hours for a load of towels to dry and even light loads do not dry properly. I just had my vent under the house...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Whirlpool LER5636P Electric Dryer
My dryer whirlpool stopped in the middle of a
You have 2 problems.
1. a blown thermal fuse on the exhaust duct. It is white in color. About 1 and 1/2 inches long by 1/2 inch wide.It is on the back of the dryer. Unplug the dryer and remove the back panel.
2. Your exhaust system is blocked or clogged with lint.You must find and clear the blockage or you will blow the new fuse.
Jan 04, 2010 | Whirlpool Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
All of a sudden the dryer will not start.
your start button may need to be replaced and if you have a warranty on it since all brand new ones do call the service or repair office to have it checked out and fixed.have a good day and happy easter.
Apr 11, 2009 | Dryers
Whirlpool dryer wont turn on
Hi Joe,
Your thermal fuse has blown. It's a cheap little part, here it is.
To get to it, Pull the dryer out and unplug it. Remove the rear panel. As you're viewing the dryer from the rear, look just to the left of the dryer exhaust... you'll see it there. It has 2 blue wire connected to it.
Remove the wires, remove the old fuse, install the new one, install the wires and replace the back panel.
There ya go! FixYa! Please take a moment to rate this as "solved".
Thanks,
SG
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer model LE5795XPWO
does it run ..if it runs and do not heat check thermal fuse.if it dont run check lid switch..alway unplug first
Dec 10, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
256 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
