Question about Sanyo DS24425 24" TV
Rca f25432 have half screen.
Rcaf25432 ctc203ad need vert block cap loc list all of them,if some one have it,thank you.,tv have half screen white.symtoms like shorted cap.
  • Anonymous Feb 14, 2008
    I can not see the whole picture. It is concaving outward. How can I bring it back t normal view?
  • 2,336 Answers
If you are experiencing the vertical issues, I would check the tuner for poorly solder aroound the ground shield if the tuner is the one integrated on the main board.
Check this sity for the schematic diagram as well: //http://www.eserviceinfo.com/download.php?fileid=31473
Good Luck.
Posted on Jan 25, 2008
HALF OF SCREEN
you have vert problem caps or chip
Jul 18, 2010 | Akai CFT2490 24" TV
Tuner connection broke
set tuner cap re solder with tuner fix this problum solve esyly but don,t fix it your self if your not tv.techician.becous it is a dengerus for you.
tv. tuner is not costly.
Nov 16, 2009 | RCA F25432 25" TV
There's a very narrow line (white) appears at the very top of the screen when the picture scene is mostly black. A verticle adjustment should fix it but where is it?? RCA F36TF720
it may be an electrolytic cap problem as most newer sets are controlled by an I.C. chip for horiz and vert timing/size/linerity
Nov 02, 2009 | RCA F36TF720 36" TV
My RCA F36648 36" TV has only the bottom half of my picture working. The top half has horizontal lines that distorte the picture. It looks like when you pull a rake through the sand the lines that are left...
You have vertical output problems.There is distortion at the top because of a faulty vert. output i.c. or a faulty electrolytic capacitor.It's possible there may be a problem at your yoke also.It needs a professional repair.
Sep 29, 2009 | RCA F36648 36" TV
NEED ASSISTANCE
Here is the infomation you need...
Feb 16, 2008 | RCA F25432 25" TV
Wide white horizontal bar
do actual replacement of all electrolytic capacitor surrounding from the vertical ic.
Jan 19, 2008 | Sanyo DS24425 24" TV
Rca f25432
picture blury problem is due to 1 focus wire loose or disconnected due to long life of connection.this wire is in crt base. 2 focus control mistunned. 3 low voltage on crt electodes. 4 if tv is old then crt is getting weak. 5 crt base or connector loose hope this helps. good luck
Sep 29, 2007 | RCA F25432 25" TV
RCA F25432 25in
If you ONLY have an Antenna or Cable input, you are going to need a Video & Audio to RF converter.. This connects to ya DVD Video & Sound OUT, and then connects to ya sets Antenna IN. This device converts ya Video & Audio signal to Radio Frequency Signal that can be "Received" by ya set. (Basically a low power TV transmitter) This is the only way I know of, if ya haven't got any other Inputs into a set.
Aug 15, 2007 | RCA F25432 25" TV
RCA Model number F25432
the horizontal output transistor my be shorted out, or the flyback transformer my be open? Have you unsoldered and tested? If you are not a technician, or have no experience I would not suggest to work on the tv yourself. good luck, Mike
Nov 27, 2006 | RCA F25432 25" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sanyo DS24425 24" TV Logo
82 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
