Question about Dell Inspiron E1505 Notebook
Dell Laptop Battery Charer
I have got a wierd problem. The battery charger for my laptop is not working propely. The laptop seems to work with the A/C power, but the battery is not getting charged. Currently I am using my friends charger and everything is working fine. The problem seems to be with the charger, i.e., it is giving the laptop A/C power supply, but not able to charge the battery.
    Problem Solver:
  • 6 Answers
Generally the LI ion material is nucleus in the laptop battery inside, It with suited manage power supply electrocircuit make up of laptop battery. It’s encase in the laptop inside charge and use. result in because high temperature condition work on long time. But the LI ion battery apply use condition temperature 25-30℃ confine. Therefore at laptop host computer temperature high attain 40℃ usually, so have existence blast or combustion latency safety problem and shorten use life the battery.c
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
Posted on May 04, 2009
    Scholar:
  • 94 Answers
There are several things that could do what you are experiencing:
1: verify that you are using a 4.62A (90watt) power supply.
2: If you have to hold the DC connector before the charge light comes on, you have a faulty DC Jack (~$75-90 repair cost)
3: Check your battery in your friends laptop before investing in a new one.
Posted on Apr 01, 2008
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Or it could be a broken/damaged power pin that is causing the problem. Every time you tug or pull on the pin it causes damage...eventually it doesn't work at all. When you get it fixed you need to invest in a CRD (Cable Retention Device) like shown here. . .
Posted on Mar 04, 2008
    Genius:
  • 1,067 Answers
Ya that can happen and bad battery they have prorgram online u can test battery with to see i would buy both new
Posted on Jan 25, 2008
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
My laptop doesnt charge propely
the charging port in the laptop is either loose or has a bad soilder on it.
Apr 22, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
My Dell Insipirion 6000 is not switching on
Check for a bad battery or it is a bad charer, chek and see if the charger is putting out the right enoth voltage, if not you can by a charger at best buy,
Jun 02, 2011 | Dell Inspiron 6000 Notebook
My laptop is dell inspiron 1525 but battery is not charging i have replaced the battery and even i have used new adapter but i cant solve the problem please help me to fix it
Hi
please remove the battery, plug-in the charger and turn ON the laptop, if it doesn't work,
then the internal part that connects the laptop to the charger have problem and need to be fixed through a technician.
Good Luck
May 13, 2011 | Dell Inspiron 1525 Notebook
When I plug in the adapter the blue light on the charger goes out immediately and does not charge the battery. I bought a new charger and it does the same thing. I've had both chargers checked and they are...
A bad battery is a definite possibility. Shorted cells are one of the ways they can fail, and then they put too much of a drain on the charger. Take the battery out of the laptop and see if the charger light stays on. This will eliminate the computer itself as the cause. Then you'll know you need to shop for a replacement battery. Replacement batteries are available from many sources online.
Mar 23, 2010 | Dell Studio 1737 Laptop
Laptop will not charge..
First of all, it could definitely be something with the battery. Batteries have a finite life-time, and yours might had reached it's end...
Anyway, chargers for laptops are quite "unique" for each brand, sometime even for each model. There's a chance that by your "trial and error" you might even caused more damage... :/ You should CAREFULLY take a look on what your laptop consumes, in terms of VOLTAGE and CURRENT. Connecting incompatible charger (even if it's plug fits perfectly) might (and often will) damage your battery and/or the motherboard.
With that said, try replace the battery (if you can try it without buying a new one - better), then use your ORIGINAL charger. Of that doesn't work - use a replacement branded charger. If that doesn't work either - you might need to check it the laptop still works.
Mar 10, 2010 | Dell Computers & Internet
Charger not recognized
Folks.
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron E1505 Notebook Logo
241 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
