Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Flashing LEDs on touchpad, erratic indications, not all functions are selectable
I am trying to diagnose the touchpad console on my KA Superba KUDS25SHBTO Ser.# FJ1303305. The tech sheet doesn't show a matrix for testing the 14 pins. Is there one available? I saw a schematic for the touchpad for the KUD24 but unable to find one for my unit. Thanks
  • 770 Answers
Is there 7 flashing lites?? if so this is a known prob with them and i can get you the tech sheet for the fix
Posted on Jan 25, 2008
KA Superba. Why are normal and rinse only lights flashing?
depending on your model number try youtube for best repair videos and reboots
Dec 16, 2015 | Dishwashers
Flashing indicator light
follow the next steps and fix it. God bless you
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 06, 2013 | Dishwashers
Touchpad responses erratically on Dell Inspiron 5100. seems to have started acting up immediately after an automatic windows update. Have already updated to the latest drivers with no effect. wireless...
Try to roll back the touchpad driver and this will fix the problem.
1 right click on 'my computer'
2 select manage
3 select device manager
4 select the touchpad from the list
5 right click on the touchpad driver details
6 click update
7 in the next window there will be an updating option alone with an roll back option
May 30, 2011 | Dell Inspiron 5100 Notebook
I'll move the cursor to one spot on the desktop and it will move itself to 7
You mean, the cursor is erratic and moving all around here and there?
Decrease the Touchpad Sensitivity...
I see that your Laptop was shipped with Windows Vista and it seems you are using a Retail version of Windows 7. Specially, HP/Compaq Laptops is designed for Retail versions and you can face some device/driver functionality issues. But, you can still try the followings.
As per my knowledge, your Laptop has the Synaptics Toucpad.
To Change the Sensitivity of the Touchpad:
1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
2. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings. In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
3. Select the PalmCheck option to adjust the sensitivity (decrease it) of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
If the Device Setting tab is missing.....
1. Click Start, in the Start search field type Msconfig and press enter.
"System Configuration Utility" box will pop up on the screen.
2. Click the Startup tab.
3. Search for "Syntpenh" entry and select the checkbox beside it.
5. Click OK. Restart the computer. Perform above step.
If you are still not able to perform the steps, update the driver from following link.
Synaptics TouchPad Driver:
Restart the Notebook and check for the problem. It should be resolved now.
Aug 22, 2010 | HP Pavilion dv9000z Notebook
The touchpad pointer is becoming increasingly erratic. For example it will not point easily where i am trying to locate;it jumps at random around the screen; it highlights without this function being...
Try to go to device manager by clicking start > right click computer then
click manage > then click device manager > click the arrow beside mouse proterties
> then right click the device and click uninstall
then download this link:
select the touchpad driver and install the software...
hope this helps...
May 10, 2010 | Acer Aspire 5720 Notebook
-FO code indicating
The error code F0 indicates a stucked function key. Just replace the touchpad or if the touchpad is part of the clock, replace the clock (ERC), and you will good to go.
Hope it helps.
Thank you for using FixYa.
May 06, 2010 | Magic Chef 31000 Gas Kitchen Range
My xbox 360
Call Microsoft and send it back or go to to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Wii-Mote LEDs will not quit flashing?
Try taking the batteries out and putting them back in. Then unplug your console from the outlet for thirty seconds and plug it back in. Then follow the directions in your manual about syncing the Wiimote to the console.
Mar 23, 2008 | Nintendo Wii Console
Touchpad do not work and neither the indicator leds.
You might check to see if the touchpad is locked.
Nov 15, 2007 | Toshiba Satellite A60 Notebook
Dishwashers Logo
221 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
