Question about Microsoft Windows XP Home Edition
Desktop tab disappear from display properties.can someone help me to fix it?
  • 3 more comments
  • lakerfan24 Apr 24, 2008
    well my computer has the desktop and the start bar disappearing....but ive read to look for a process called sysu.exe in the task manager to fix it. This hasnt worked. So if anyone can help me.... id really apreciate it....
  • 3144 r Aug 31, 2008
    I TRIED TO CHANGE THE DESKTOP BACKGROUND IN CONTROL PANEL BUT I CANNOT FIND THE DESKTOP TAB!
  • freddyboen May 11, 2010
    I have lost the two of the tabs in Display and one is Screen Saver.
    How can I get it back.
    Freddy
  • Carl Sizemore
    Carl Sizemore May 11, 2010
    When posting problems of this nature you need to provide more information. For instance depending on what operating system you are using will greatly affect our ability to answer your question.
  • Emelio Navaja
    Emelio Navaja May 11, 2010
    can u show me the picture of your problem or what particular problem in the desktop?
    Novelist:
    Champion:
  • 202 Answers
Paste the following into a file with an extension .reg and run it, it shall solve ur problem
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"NoDispBackgroundPage"=dword:00000000
Posted on Jan 26, 2008
    Novelist:
  • 109 Answers
The desktoptab can be disabled by your Systems Administrator. For example in a corporate environment or a school.
There's a thing you can try though:
1. Go to Start -> Run and type: gpedit.msc and hit the Enter/Return key on your keyboard.
2. Go to User Configuration in the tree on the left. Select Administrative Templates.
3. In Administrative Templates select Windows Components.
4. In Windows Components select Windows Explorer.
5. A list of properties appears to your right. Go to "Turn on classic shell". Doubleclick on it.
6. A dialog appears with a few options. Select "Not configured" and click Apply and then OK.
If done correctly try going to the Display properties tab again. The Desktop-tab should be visible now. This can take a minute or two however after you changed the setting. So if it isn't there the first time, try it again.
Note: if you cannot use gpedit, or Run then your System Administrator had blocked it. Then there is nothing to do.
Let me know if this helped you out, please rate.
Greetings,
DarkNeogen
Posted on Jan 25, 2008
    Genius:
  • 1,226 Answers
All the posted solution are correct, however if all the solution posted is not for you then, maybe you should scan your system with a potent antivirus, you can do this attaching your HDD to some other computer and scan your HDD there, however if hard for you to do the task, then try boot your system at safemode, by pressing "F8" when computer start and you prompted to boot option.
May this help, leave comment fefore you rate, thanks!
Posted on Jan 27, 2008
My monitor says out of range
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Sep 01, 2011 | Insignia D300a PC Desktop
Hi, My monitor has dull display. After starting my computer, I could see the desktop but after few seconds it disappears. I am sure whats happening. Please suggest me what to do.
My answer will help Windows XP and Windows 7 users.
When the computer starts, start pressing F8 button. After several seconds you will see the following menu.
Safe Mode Safe Mode with Networking Safe Mode with Command Prompt ---------------------------- ---------------------------- ----------------------------
If you have Win XP, there will be a menu item as 'Enable VGA Mode'. In Win 7 you will see 'Enable low-resolution video (640 x 480)'
Select this option and press enter. (XP users will have to enter again).
After the computer is ready, goto display properties and save the resolution.
- In XP right-click on desktop, select 'Properties', Click the 'Settings' tab (last tab on top), and click 'OK' button.
- In Win 7, Right-click on screen and select 'Screen Resolution'. Click 'OK' button.
(Ignore any warnings)
Restart the computer.
Set the screen resolution again to a reasonable setting.
- Be careful! If you set it too high (if the monitor does not support the resolution you select), again the screen might disappear! (Sometimes this happen automatically after installing a game)
Jul 19, 2011 | Dell E176FPC Monitor
How do I increase screen resolution in PC mode running Windows XP Pro?
To change your monitor's resolution
1. Right-click the desktop, and then click Properties.
2. In the Display Properties dialog box, click the Settings tab.
3. Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4. Click Apply to have the new resolution take effect.
5. If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6. Click OK.
Hope this help.
Mar 21, 2011 | Computers & Internet
Taskbar has disappeared and the text has gone very small. Can you help hp pavilion home pc. Windows XP
This may be due to the resolution problem.
right click on Desktop -> select Properties
There under settings tab, reduce the resolution using the slider and click ok.
Now you should be getting display as usual.
Using the control on your monitor, adjust the display to show the task bar, in case hidden due to improper settings.
I hope this is helpful in solving your problem.
Please rate the solution provided.
Thanks
Mar 10, 2010 | Computers & Internet
Battery icon disappeared from bottom of screen
Right-click on your desktop
Click Properties
Click "Screen Saver" tab
Click "Power" button
another window will appear that says "Power Options Properties"
click "Advanced" tab
check "Always show icon on the task bar" click apply
Apr 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
I can't change my desktop background
Probably your desktop background is locked.
To unlock your desktop do this:
Start >> Control Panel >> Display >> Then select tab "Desktop" and go to "Customize Desktop"
Then select tab >> Web >> Uncheck or delete the locked items.
This will be fixing your problem.
Don't forget to rate my help!
Thak you for using FIXYA!
Pablo :-)
Oct 14, 2008 | Computers & Internet
Tabs in display properties window
You got to perform some updates for that. here the link helps you in steps doin performing that update. click here
DOnt forget to rate this post
Aug 19, 2008 | Microsoft Windows XP Professional
Desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
Microsoft Windows XP Home Edition Logo
424 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
